05-18-2021, 11:03 AM | #491 |
Drives: Former Owner '16 Camaro 2LT V6 conv Join Date: May 2021
I’m working on a firm letter to accompany my TC replacement request. Where on the TSB is it written that the dealer need not reproduce the problem? Or is it just NOT written that they NEED to reproduce it.
05-18-2021, 12:03 PM | #492 | |
"Diagnosis beyond the customer compliant is not required if vehicle was built prior to production dates indicated above" ...the covered date range being from SOP (start of production, I believe) to Feb 1, 2019. Yes, it does say customer compliant, hope this isn't some massive Freudian on their part .
05-18-2021, 01:42 PM | #493 |
Ok i see. Thought that could be interpreters as further investigation beyond the TC problem didn’t need to be done.
05-18-2021, 09:11 PM | #494 |
Drives: 2018 Camaro SS vert Join Date: Oct 2020
Have had the range AFM since day 1
05-19-2021, 06:42 AM | #495 | |
Drives: 2023 2SS Convertible Join Date: May 2009
-Geoff
05-19-2021, 07:19 AM | #496 | |
1- go down hill at constant speed in 5th+ gear so engine is idle or close to it and TC is unlocked 2- transition to up hill so Engine applies power. Tranny will stay in current gear or down shift. Tc will shudder in this transition when trying to lock. Shudder lasts for a brief moment to a couple seconds. Doesn’t do it every time tho. General question too. The old 4 speeds would shift thru the gears then the TC lock would be OD. Does this tranny lock in every gear? That’s how it feels. |
05-19-2021, 10:11 AM | #497 | |
-Geoff
05-20-2021, 05:13 PM | #498 |
Got my car back - smooth as silk in about 10 miles on the highway. I got to the same spot and speed where it would shudder at 64 mph and nothing happened. Very happy with the fix so far!
-Geoff
05-22-2021, 11:16 AM | #499 |
I just talked to the head mechanic at the dealer. He said the TC should be fine and another flush is probably all it needs. Have it scheduled for a few weeks. Need to make sure it’ll be a warranty thing.
06-21-2021, 01:14 PM | #500 |
I got a second flush and put 600 miles on it. It’s a good deal better, but not gone. I still get a bit at certain times and still suspect damaged TC.
07-27-2021, 08:27 PM | #501 |
Drives: Red Hot 2017 2SS, A8, Mag Ride Join Date: May 2018
A8 Tranny Shudder on my 2017 SS with only 17,000 k/m on it
I am bringing it into my dealer tomorrow morning, hopefully it is a free repair as per:
https://static.nhtsa.gov/odi/tsbs/20...54635-9999.pdf On Wednesday July 28th Addison Chev in Mississauga, Ontario did the TSB #18-NA-355 and they used 20 liters of that Mobil 1 Synthetic LV ATF HP (with the Blue Label). Thankfully GM covered the cost. The car only has 17,700 k/m (approximately 11,000 miles) on it. Seems OK now on my highway return trip home. Hopefully that did the trick. Last edited by Kramer1986; 07-28-2021 at 08:02 PM. |
08-02-2021, 09:10 AM | #502 |
I’ll give an update for my car. I had the first flush (current TSB) around 25 or 30k. Improved 80% but still shuddered. Got another flush around 40k and saw minor improvement. Now at 44k it goes in next week to be looked over and the tech on the phone sounded like it would be approved for a warranty TC replacement.
It looks like everything will be done before warranty is up. What happens if I still have trouble after a TC replacement and my warranty is out? Will they still service it on their dime since it’s the same problem that manifested while under warranty? |
08-02-2021, 09:37 AM | #503 | |
There was a class action against GM about the 8L90, since the same problem occurs in their other cars and trucks, not sure if it got anywhere.
08-02-2021, 01:11 PM | #504 | |
I was reading about stall speeds somewhere on here, and that particular forum was debating whether or not to go aftermarket TC or GM. They seemed to think the OEM TC was defective. Is this strictly a fluid issue or does the TC also have problems? |
