#491 |
![]() Drives: 18 1LE/1SS, 08 G8 GT, 13 GTI Join Date: May 2017
I did the kit for both seats last week. Works great! Only thing I would note, is to install the switch with the led towards the bottom. That makes it more natural up-on/down-off switch movement, and the led light is more visible that way. So nice to not have my backside feel smothered and sweaty!
#492 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 17 Camaro SS 1LE & 16 Sierra AT CC Join Date: Nov 2016
How long did the install take you? I am thinking of doing mine this weekend.
2017 Camaro SS 1LE - Procharger D1SC w/ Tial 2" BOV & Race intercooler / ARH full length catless headers / Alky meth injection system - 650rwhp on conservative tune SOLD |
#493 |
#494 |
![]() Drives: '18 1LE '16 Z06 '22 Z51 '23 Z06 Join Date: Mar 2011
Gen5Diy Fan harness
Gen5Diy has brought a great addition/solution to the 1SS/1LE group with their cooling fan harness!
Install in about 3 hrs taking my time now I'm a cool ass dude...lol sorry couldn't resist BTW I also bought the Homelink console for my 1SS, install less than 15 minutes. Thanks Gen5diy!
#495 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 SS 1LE, 2017 Volt, 2013 Pilot Join Date: May 2014
How are you guys adjusting the fan speed as described in the video? In the video they adjust on the bench, but I don't have a way to do that.
so, cable everything together but don't bolt down the seats before adjusting?
#496 |
You can do it by doing the adjustment before you bolt down the seat, plug it all in and use the switch to set the seat as high as you can, then if need more room tilt it up from the back.
#497 |
yup... gonna see if i can get my fat head down low enough
![]() i'll use my ears and maybe a mirror.
#498 |
![]() Drives: DZ Join Date: Aug 2018
The trick I used to setting the fan speed is to just barely touch the fan while it is running so I could "hear" the nubs on the inner part of the fan touching my finger. These kind of fans won't hurt you at all, but by doing this I could dial up the speed until the fan stopped and then just slowly roll the knob back until the fan started again. Then just moved onto the other seat.
With the exception of crimped on terminals for the switch (I had two come off just routing the wires thru the seat - so I soldered the wires to the switch and heat-shrunk the connections), I think the kit is a great investment and worth the money |
#499 | |
i like what u did withe the switch, i actually didnt have good contnuity on one and thought i had a bad kit or fan. popped the switch and it looked like loose connection, i just used needle nose and crimped.
#500 |
install completed.
my derričre
#501 |
I was able to adjust the knobs with the seats bolted down. Just have to listen for the fans turning on and off.
#502 | |
![]() Drives: 2017 1LE Join Date: Nov 2017
'17 Bright Yellow 1LE. PDR, STB, !CAGS
Borla 60606, 11925. Tony Mamo ported TB, ROTOFAB, !Sound Tube Last edited by Chris C 1SS 1LE; 06-23-2019 at 10:44 AM. Reason: Spelling... |
#503 |
![]() Drives: 2018 SS 1LE Join Date: Aug 2018
Silly question, I know, but I'm assuming you disconnect the negative battery terminal before unplugging the harnesses under the seats, correct?? It wasn't shown or mentioned in the installation video.
Also does anyone know if the the small triangular switch panels on the sides of the seats replaceable if you ever want to return to stock? |
#504 |
![]() Drives: 2019 Satin Steel 1SS 1LE w/ PDR Join Date: Sep 2017
