Old 08-01-2019, 10:09 AM   #477
Alain
Alain's Avatar
Originally Posted by Deputy Dog View Post
Are you all removing the TB before trying to unlatch the connector?
That’s the way I did it and it made it really easy to deal with the clip.
2018 ZL1 1LE/Red hot
Old 08-01-2019, 11:48 AM   #478
Mike@SolerPerformanceLLC
Mike@SolerPerformanceLLC's Avatar
Drives: 2015 Corvette Stingray
Originally Posted by AlphaCamaro7 View Post
can anyone tell me what the difference between this TB and 103mm TB and which one is better? im really confused.
Alpha, what Spartan and Nitefall said is exactly right.
If you prefer the best of both worlds wait for our Modified OEM 95 mm which will be good for 850+ HP setups (will need tune), BTW the 103 is not OEM.
If you do not want to tune, our current one at 91 mm effective at WOT and great response right off idle will do the job.
Thanks,
Mike@SolerPerformanceLLC is offline   Reply With Quote
Old 08-01-2019, 11:52 AM   #479
Originally Posted by Mighty Mouce View Post
Clip removal instructions nothing like the clip on my TB. The plastic tab on my wiring connector clip broke off, now I have nothing to release the connector to pull off wiring!
How can I get this off without doing more damage?
Mighty Mouse; could you e-mail us? We'll send you a replacement connector pigtail (the one with red tab).
Old 08-04-2019, 12:54 PM   #480
Deputy Dog
Drives: 2017 Super Sport Cam.
Originally Posted by CamaroVille View Post
I am getting ready to order one of these and I have a question...
In reference to the "Relearn-and-Test-Instructions-Rev-NEW-V5.pdf" document found on the FAQ section of www.solerengineering.com...
Test and Re-learn Instructions (Procedure B) - Step 3 Says "Start engine and allow engine to idle at 650 RPM for three additional minutes and until redline
has retracted to 6500 RPM.
I have a 2018 2SS and the redline is printed on the tachometer at 6500 RPM. Does this only apply to the ZL1? or am I missing something?
Misprint...pretty sure the 6500 RPM should be 650/idle.
Deputy Dog is offline   Reply With Quote
Old 08-05-2019, 10:53 AM   #481
L8Apex
Drives: 2016 2SS
I never saw my redline change, it stayed at 6500 on mine, so moot point for me. Should idle at about 650 tho
L8Apex is offline   Reply With Quote
Old 08-05-2019, 11:47 AM   #482
Mick0311
Drives: 2018 Camaro 2SS Redline
The 6500 redline is in regards to Corvettes with the digital gauges.
Mick0311 is offline   Reply With Quote
Old 08-05-2019, 03:13 PM   #483
CamaroVille
Drives: 2018 Camaro 2SS M6
Mike has already answered this... The "Relearn-and-Test-Instructions-Rev-NEW-V5.pdf" document was written for Vettes that have the Red Line built into the LCD display. He said that he will be updating the doc soon. The intent is to let the car warm up prior to the next step.
Rick
2018 Camaro 2SS M6 NPP
HBM w/Black Metallic Rally Stripes
Built 6/21/18 -- Purchased 7/28/18
CamaroVille is offline   Reply With Quote
Old 08-05-2019, 06:06 PM   #484
MackSteelPrivateEye
Installed my TB over the weekend did the relearn w/o the Batt disconnect. Did the drive, up to about 96 miles. So far at about 1800 to 2500 rpm I feel just a slight unsmoothness. I assume its still learning and this will eventually go away...right? I punched it a couple of times, definatley get a bigger tire chirp banging into 3rd gear coming off a ramp. Will it get even quicker as it learns and smooths out?
Old 08-05-2019, 10:02 PM   #485
Deputy Dog
Old 08-06-2019, 10:08 AM   #486
All2Easy
Drives: 2015 Z/28 #997 Gone 2019 SS 1LE
I have noticed the same. When I installed mine, I disconnected the battery overnight.
For me, seems between 2-3000 rpm in second or third gear during non-aggressive acceleration, I get what I would describe is a bit of surging.
Anyone else feel this?
Overall, the car does respond off the line better than stock.
All2Easy is offline   Reply With Quote
Old 08-06-2019, 11:07 AM   #487
MackSteelPrivateEye
Yeh...exactly my symptoms too. Only feel the surge in casual takeoffs from a stop. Its about 1800 to 3000rpm. Also first startup in the morning just before the idle settles to 650 rpm it will surge up a few rpms for 5 or 10 sec. before going back to 650. Did disconnecting your batt fix it or you still have it?
Old 08-06-2019, 11:20 AM   #488
camaroJD
Drives: 2019 Satin Steel 1SS 1LE w/ PDR
I'm right at about 100 miles since the install and I noticed this once. I was hoping it was just part of the re-learn.
camaroJD is offline   Reply With Quote
Old 08-06-2019, 11:22 AM   #489
MackSteelPrivateEye
Perhaps SOLAR can shine some SUN LIGHT on this.
Old 08-06-2019, 12:26 PM   #490
All2Easy
I have about 500 miles on the car since installation with the slight surge I noted above still being present.
