Go Back   CAMARO6 > CAMARO6.com General Forums > Z/28 Discussions
Old 05-13-2016, 10:22 AM   #477
jessrayo
Speed Freak
jessrayo's Avatar
Drives: 2013 ZL1 Camaro, 2016 Camaro SS
Originally Posted by Bhobbs View Post
Twin turbos don't fit in the Corvette, so that's out the window. It's the LT4. It has to be the LT4 because that's the only engine GM has to use.
Here are a few links I found in a very quick search. This mid-engine vette is being worked on right now. GM has been leaking bits of information on it for a long time. There will be plenty of room for turbos on this mid-engine car. I'm fairly certain that this Zora and this new Z/28 will share an engine that GM has not yet revealed the details about. Don't know which release will come out first but I have been saying for a long time... the new Z/28 will have turbos..... and it will crush everything in its class that has been built to date.....everything.
http://www.caranddriver.com/features...ng-for-feature
http://www.roadandtrack.com/new-cars...tte-test-mule/
http://carsintrend.com/2017-chevrole...-release-date/
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date.
jessrayo is offline   Reply With Quote
Old 05-13-2016, 10:24 AM   #478
Raven87
C'mon- really?
Raven87's Avatar
Drives: Looking for a ZL1
Man, I hope you are right. TT's on the car would be killer indeed.
Steve
2018 Camaro 2SS 1LE Black #3805 - SOLD
Raven87 is offline   Reply With Quote
Old 05-13-2016, 10:37 AM   #479
Bhobbs
Bhobbs's Avatar
I've seen those all before and I won't believe them until I see a mid engine Corvette.
Do you honestly expect GM to put the engine for its halo car in a Camaro costing 1/4 the price? They didn't put the LS7 in the Camaro until after the Corvette using it went out of production.
Old 05-13-2016, 10:42 AM   #480
Thor142
Thor142's Avatar
Drives: 2014 2LS (traded in) 2015 1SS 1LE
Exactly. There are 2 possible Camaro engines and we already know what they are.
Thor142 is offline   Reply With Quote
Old 05-13-2016, 10:55 AM   #481
newb
newb's Avatar
Drives: 2013 1LE
It was said around the release of the 6th Gen Camaro that the M7 transmission didn't and that's why they went with the M6. So it doesn't make sense that the A10 fits the Camaro and not the C7. I'm sure it will happen. In due time. The fact that they did not incorporate it yet gives credibility to the argument that the Corvette team is busy with something big.
It's a Dingledarm. It's there to dampen side fumbling. If your marzelvanes fumble too much they can cause total protonic reversal. It gets ugly from there. This is really the biggest problem with the new Camaro. That and the tri-pronged blivot.
Delivered 21 Jan 2013
newb is offline   Reply With Quote
Old 05-13-2016, 11:06 AM   #482
shaffe
Drives: 21 Bronco
This ^
regardless of what any one wants to think, the Corvette still sits atop the mountain at GM
Lets keep it simple. ..
Old 05-13-2016, 11:06 AM   #483
jamminj007
jamminj007's Avatar
Drives: 2016 Camaro Black 2SS, 69 Camaro
If this is truly to be an intended track car, I cannot see them putting the LT4 in the Z/28 due to heat soak and weight. I can see why they did it for the ZL1 it has all of the bells and whistles whereas the "luxury" items will be an option. I could be wrong
2 SS Murderd
69 Camaro Pro-Touring
jamminj007 is offline   Reply With Quote
Old 05-13-2016, 11:35 AM   #484
mjk3888
"M1SS1LE"
mjk3888's Avatar
Drives: 2017 SS 1LE
For the last time people!!! The camaro will not have cooling issues even with an LT4 the corvettes issues were due to lack of air flow. Looking at this image you can see the difference in grill openings!
Old 05-13-2016, 11:40 AM   #485
Raven87
C'mon- really?
Raven87's Avatar
Originally Posted by shaffe View Post
This ^
^^^THIS^^^
Especially against the Camaro. We Camaro fans may want it to be otherwise but there is still a super powerful Corvette lobby within GM that pulls a LOT of strings when it comes to any other GM model.
Should not be the case but it definitely is.
Steve
Old 05-13-2016, 11:44 AM   #486
shaffe
Drives: 21 Bronco
Originally Posted by Raven87 View Post
^^^THIS^^^
And its not a bad thing, I don't get why some people think it is. If you have to get trickle down tech or share stuff with another car, the Corvette is a damn good place to start lol
Old 05-13-2016, 12:01 PM   #487
Bhobbs
Bhobbs's Avatar
It's only a bad thing when the Corvette goes in a direction that doesn't allow you to effectively compete in areas your segment.
Yes, the V6 and SS outperform the Mustang but an LT4 Z/28 leaves the GT350 unchallenged. Plus, Ford being Ford, the GT500 is likely to make more power than the Hellcat. So, now there is a situation where two nearly identical Camaro hi po version likely won't counter the Mustang variants.
Old 05-13-2016, 12:09 PM   #488
FenwickHockey65
General Motors Aficionado
FenwickHockey65's Avatar
Well to be fair, they stuck the LS9-derived LSA in plenty of less expensive products. I know it's not the same thing, but in today's climate very few engines are exclusive to one product. Cadillac's LGW is the only one that comes to mind, maybe LF4 but even that's LF3-derived.
2023 GMC Canyon Elevation
Old 05-13-2016, 12:19 PM   #489
90503
90503's Avatar
Drives: 2011 2SS/RS LS3
It may not be the most important factor, but the Z/28 would benefit from the LT4 to keep costs down...
The crying was over the 5thGen Z/28 price with a last-gasp use of the LS7 was bad enough. Imagine what it would be like with added cost and price of a Z/28 with a new, unique engine...
Old 05-13-2016, 12:20 PM   #490
JusticePete
Drives: Camaro Justice
Not sure I am following your thinking.
JusticePete is offline   Reply With Quote
