Old 07-27-2019, 08:15 AM   #463
Deputy Dog
Drives: 2017 Super Sport Cam.
Originally Posted by Mike@SolerPerformanceLLC View Post
Please, see post #161, link below. Watch that video. Courtesy of Trochoidal and Lethal Camaro. We are in the process of rewriting our instructions for this connector as well.
https://www.camaro6.com/forums/showp...&postcount=161
Thanks,
Says nothing about removing the tab.
Deputy Dog is offline   Reply With Quote
Old 07-28-2019, 10:47 AM   #464
Mighty Mouce
Drives: Camaro
Clip Broke!
Clip removal instructions nothing like the clip on my TB. The plastic tab on my wiring connector clip broke off, now I have nothing to release the connector to pull off wiring!
How can I get this off without doing more damage?
Mighty Mouce is offline   Reply With Quote
Old 07-29-2019, 08:46 AM   #465
breadwoman
Drives: FRS
I installed mine last night. Had trouble with the grey tab like everyone else, but luckily didn't break it. The instructions that came with the TB for that part is not accurate since it refers to a red tab.
I disconnected the grey tab by pressing down onto the lower part of the "T" of the grey tab and simultaneously pulling it away from the TB using a thin flat head. It takes a couple tries but that worked.
When you're finished installing the new TB then just reconnect the connector then press down on the grey tab again and push it in.
breadwoman is offline   Reply With Quote
Old 07-29-2019, 08:58 AM   #466
Z650HP
Z650HP's Avatar
Drives: 2019 Black ZL1 M6
Can't understand the problem people have with the tab. I can literally disconnect in seconds every time with no tools. Simple simple.
I don't know maybe the tab is different on a 2019 ZL1.
Z650HP is offline   Reply With Quote
Old 07-29-2019, 09:01 AM   #467
camaroJD
Drives: 2019 Satin Steel 1SS 1LE w/ PDR
I'm guessing the 2019 tabs are different. I always have an issue with the various GM plastic connectors and had no problem with mine.
On that note, today will be day one of the relearn!
camaroJD is offline   Reply With Quote
Old 07-29-2019, 09:49 AM   #468
Mighty Mouce
Drives: Camaro
Mine didn't have a red or gray tab. Black tab the same color as the connector itself. 17' model.
Old 07-30-2019, 09:34 AM   #469
staples87
Drives: 2017 Camaro ZL1
Are you sure? It's underneath and very hard to see. I have a red tab that had to be pulled out before unlatching the connector. That's on my '17 ZL1.
'17 Camaro ZL1 M6
staples87 is offline   Reply With Quote
Old 07-30-2019, 10:53 PM   #470
breadwoman
Drives: FRS
So it seems like GM used possibly 3 different variations of connectors lol. Mine is a 17 SS 1LE
Old 07-31-2019, 03:29 AM   #471
Z650HP
Z650HP's Avatar
It seem's like the ZL1/ZLE guys are getting the bog back after the ECM fully adapts. Have any of the LT1 guys experienced this as well? It seems like this only applies to LT4 at this point unless people are just keeping quiet.
I just bought this TB last week and wondering if it's worth switching. I'm positive that it does everything that Soler claims, but if the ECM is overriding the physical benefits then there's really no point without a tune.
This is not true in my car. I've put about 850 miles on mine now, so lots of learn cycles and it's better then ever. Throttle response is instant and drive ability is excellent.
Old 07-31-2019, 06:20 AM   #472
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
Some people are all thumbs
ing for grip.
http://www.motorsportsne.com/
Old 07-31-2019, 06:38 AM   #473
AlphaCamaro7
AlphaCamaro7's Avatar
Drives: 2016 Camaro 2SS, NPP, A8, FBO, E85
can anyone tell me what the difference between this TB and 103mm TB and which one is better? im really confused.
Well............ At least you tried. lol
AlphaCamaro7 is offline   Reply With Quote
Old 07-31-2019, 11:22 AM   #474
Spartan268
Spartan268's Avatar
Drives: HB 2SS
On WOT the 95mm/103mm will have a better power output. In day to day driving, using light throttle, the Soler will give a better response.
If you can wait a few months.. Soler is planning on releasing a 95mm which should trump the current ones on the market if it's as advertised
Spartan268 is offline   Reply With Quote
Old 08-01-2019, 01:22 AM   #475
Deputy Dog
Are you all removing the TB before trying to unlatch the connector?
Old 08-01-2019, 01:52 AM   #476
Nitefall17
Drives: Camaro 1SS A8 Vert
95 and 103mm TB's will need to be tuned to the car..
Soler TB does not need anything but a ECU reboot.
Also with Soler TB will have the same surface area as a 91mm, happy medium.
Nitefall17 is offline   Reply With Quote
