#463 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: Challenger SP Shaker/Arcadia Denali Join Date: Jan 2016
If you read 90% of the thread here you would understand (This is a BIG problem). It is loud and obnoxious every day for many of us here. Also there are videos here and on other threads that the noise clearly is similar to what most all of us are all dealing with. If this crap is normal then no one would be bitchin every day on it. |
#464 |
![]() Drives: 2002 Camaro SS Join Date: Jun 2012
Not to mention, many have had the oil changed and made sure it had the friction modifier. And new differentials installed.
2017 1SS Hyper Blue M6
2001 Ford Lightning |
#465 | |
The 2015 SS I had before the current 2016 had no issue whatsoever. Different diffs too. New engines, new transmissions, new diffs, new everything. It's like comparing apples to oranges. However, when compared to the vettes (same engines and so on) the issues are the same and have been problematic. I'm not waiting for the new redefined 60k mile warranty to expire before it's fixed. |
#466 |
My 2010 2ss had only 1 problem, oil pump going out at 56k miles. My 2016 2ss goes in Tuesday for an "evaluation". Fingers crossed! And the groan has become louder within 200 miles. Service writer told me this was an issue with 2014 and up corvettes, but he hadn't seen any camaros with the same issue. But I live in God's waiting room,southwest Florida, more vettes are sold down here than camaros. Just a little humor for an annoying issue.
#467 |
![]() Drives: 2016 SS 2SS HyperBlue Join Date: Aug 2016
I noticed the groan today.
2016 2SS with 1550 miles.. |
#468 |
Drives: 2010 Chevy Camaro 2LT / RS / Auto Join Date: Jan 2010
Here is a nice article on MotorTrend.com talking about this issue:
http://www.motortrend.com/cars/chevr...view-update-4/ |
#469 |
![]() Drives: 2016 Camaro 2SS Join Date: May 2016
Sign me up for the "groan". 16' 2SS, A8, 10k miles. Not bad but it is damn sure noticeable. Just started a couple days ago.
Off to the dealer next week. ![]()
#470 |
Camaros Of Northwest Ohio
Please post mileage and build date and don't forget to take the poll:
http://www.camaro6.com/forums/showthread.php?t=479244 Bill R Build Date: 2/27/2016 Current Mileage: 14,800
2023 2SS 1LE Red Hot
2016 2SS Black / Black & Arenaline Red (sold) 2023 GMC Canyon Denali 2013 2SS / RS - AGM / Jet Black (sold) 1970 1/2 Z/28 Classic Copper / Tan (sold many years ago) |
#471 |
So, I've spoken to some senior advisers at GM headquarters and they informed me that the dealership has done everything correctly because the only TSB out there on this issue is to drain and replace the rear diff fluid. This did NOT fix the issue for me and I told them that every time i hear the noise that's my rear diff clutches wearing out. I told them it's not okay to tell us to just drive on it because they will eventually fail, and it's a long term thing so it could be after the warranty is up and then it's my dime.
Unfortunately no progress, so I am not sure what it will take to get someone in GM to go out and find a root cause for the issue and deploy a real solution for all of us with this issue since the TSB they have does not solve the problem. |
#472 |
![]() Drives: 2018 Camaro 2SS, Hyper Blue Join Date: Jun 2016
I've had fluid flushes, 1st replacement diff lasted about 1,500 miles and then made noise. More fluid flushes with noise still there on replacement diff, 2nd replacement diff completed 400 miles ago and unit not driveable due to a reduced braking issue. It's been at the dealership for weeks now since I'm not picking it up until it's repaired. GM needs to step up before they lose a loyal customer.
2018 2SS, A8, NAV, NPP, MRC, Sunroof, Hyperblue, LT4 S/C, LT4 Fuel System, RotoFab CAI, Headers, HiFlo Cats
2016 2SS, A8, NAV, NPP, MRC, Sunroof, Hyperblue (GM buyback) 1999 Trans Am Firehawk, M6, headers, no-cats, slp exhaust, hot cam, intake, 3:73 gears. Red/Blk |
#473 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: camaro Join Date: May 2013
Amazing how 2 dealers by me REFUSE to try the fluid change, and tell me it's normal. It progressively gets worse with time. Last gm for me. Shame they wont fix an obvious defect. Glad I leased. I will beat the piss out of this thing. It will be limping back in at the end of lease.
Hyperblue/JetBlack |
#474 |
![]() Drives: 2016 Red Hot 1LT 6 cyl M6 Join Date: Oct 2016
I picked mine up Saturday and makes no more noise.
Cause: 3031360 Limited Slip Differential Clutch Replacement 88862624 Fluid
#475 |
![]() Drives: 2016 2SS Red Hot Join Date: May 2016
I think the article does a good job of explaining the why: Our source within Chevrolet said this on the matter: “On early 2016 [Camaro] builds that have limited-slip differentials, this was a known issue. The ring and pinion gears had too much gear-marking compound [used to evaluate/adjust pinion depth] applied by the diff supplier, which [in turn] contaminated the fluid. Doing a fluid flush fixes the issue.
At the same time it's fair and notes the following: Some folks in the forums (Camaro 6) reported that after the differential oil replacement and several walking-speed figure eights with steering at full lock (which sounds like a reasonable idea to help circulate the new oil), this was a permanent fix, some said it didn’t change a thing, and still others reported that the groan came back after a period of time and so repeated the process with various degrees of success. It seems odd that it’s so hit or miss, which might explain why some forum contributors are having difficulty convincing their local Chevrolet service writers to look up the service document and perform the oil replacement. As annoying as it may be to some, (sorry, I don't have it at this time) it doesn't sound as if it's anything that is going to damage the car.
2SS, A8, NPP, Nav, Sun Roof, Bose Audio, MM Catch Can, RPI chin splitter |
#476 | |
