Old 02-03-2016, 08:04 AM   #463
Imp
Dodges all the cones
Imp's Avatar
Drives: Soon
I keep hearing "track" where you brake, turn in, apex, feed throttle and track out where the whole thing takes more than a few seconds to go from start to finish, then you re-do that for each corner.
How does the MRC react when you have about 50-60 turns, in less than a minute? (Autox). Slaloms, VERY quick (but smooth) direction changes, etc... I get that it works great when you can make the car take a set in a turn at high-ish speeds and it takes about 5-6 seconds to PER TURN. But for autox, those 5-6 seconds are about 5-6 separate inputs and direction changes. FAST (again, but smooth) while balancing the car at 50ish mph on the edge of the tires adhesion, while balancing the car on the brakes and gas at the same time.
Can MRC keep up without overheating at national level autox? 50-60 "turns" per minute. Not 10-12 corners in 2 minutes. This is where the DSSV comes in REALLY handy as you CAN adjust the compression and rebound separately (which it is kind of necessary to separate the two for the "fast" autox drivers).
--kC
Imp is offline
Old 02-03-2016, 08:09 AM   #464
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
Can MRC keep up without overheating at national level autox? 50-60 corners per minute. Not 10-12 corners in 2 mintues.
--kC
The system is designed to handle constant adjustments on the fly, just driving down the road, 1000 times a second. It can keep up with turns of that frequency just fine. In fact, if you compare such an autox event to a pock-marked road of the same length...the autox course may actually be less of a stress on the damper.
The only thing that *might* overheat the system would be miles of bad cobblestone...
Mr. Wyndham is offline
Old 02-03-2016, 08:13 AM   #465
Number 3
Hail to the King baby!
Number 3's Avatar
Correct
Number 3 is offline
Old 02-03-2016, 09:46 AM   #466
6spdhyperblue
Drives: 2SS 1LE
when I think of it 1kHz and the DSSV is mentioned to have better transition from compression to rebound. if the controller is increased to 1mHz, that issue would go away. That should just be a matter of time no?
6spdhyperblue is offline
Old 02-03-2016, 10:15 AM   #467
Waiting46
Drives: 1981 silver corvette,Hyper Blue 2SS
That is less than a .001 seconds difference on initial rebound. And its not that MRC isn't rebounding at that point, it just may be in a non-optimum state.
Remember, MRC doesn't force it to expand or contract, it just makes it easier or harder to do it.
Waiting46 is offline
Old 02-03-2016, 10:15 AM   #468
90503
90503's Avatar
Drives: 2011 2SS/RS LS3
Looks like GM is doing a better job at keeping things a secret, so to speak....
We've had a ZL-1 forum for a while now....Looks like we'll need a real 1LE forum first...lol
90503 is offline
Old 02-03-2016, 10:27 AM   #469
ST1LE
ST1LE's Avatar
Drives: E92 BMW M3
Indeed!!!
J-Rod Built and Matt@FSP Tuned
ST1LE is offline
Old 02-03-2016, 10:40 AM   #470
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
Was thinking the same thing. "1LE General Discussion"...
SS 1LE is offline
Old 02-03-2016, 11:05 AM   #471
Jeffro19
Jeffro19's Avatar
Yes this would be nice!
Jeffro19 is offline
Old 02-03-2016, 11:44 AM   #472
aa406079
Drives: New : 2017 SS 1LE Old: 2012 TTRS M6
If you want MRC, and the 1LE doesn't have it available, just get it added to your SS as an option when you buy....The one-size fits all ride quality set-up is already available, with or without MRC...
(Believe it or not, you can track any Camaro in any stock configuration)...
If you want more track goodies, just upgrade your car with aftermarket struts, sways, tires and wheels etc., from the aftermarket (or use 1LE parts)....I don't think the 1LE will be available with MRC....It could have been an option on the 5thGen but wasn't...
As much as the 1L-E is praised, it can be mostly copied or out-done....The 1LE offers a track option straight from the factory that is very nice, and probably reasonably affordable, but it's not the only way to go. You can DIY to your heart's content for street or track with whatever configuration your SS currently has.
Give the 1LE a break...lol...It's one of many SS options...take it or leave it.
Thanks man, glad you set us straight by telling me to pay $8,000 in parts and labour for an MRC SS that won't understeer near the limit at the track....
Fortunately , neither of our opinions will mean much in a week.
Much cheaper to retrofit MRC onto a 1LE than retrofit 1LE onto an SS...
aa406079 is offline
Old 02-03-2016, 12:32 PM   #473
mjk3888
"M1SS1LE"
mjk3888's Avatar
Drives: 2017 SS 1LE
We do need a 1LE section of the forums!
mjk3888 is offline
Old 02-03-2016, 12:40 PM   #474
oneredry
HYPER SS
oneredry's Avatar
Drives: 2016 Supercharged 2SS
I've said this once before, I bet my 0.50 paycheck that we see this (if its revealed as they predict) will be a Zl1, not a 1LE. just a wild guess.
Ordered: 1/15/2016
2000 status 02/01/16
3000 status 02/29/16
3400 status 03/07/16 TPW of 03/14/16
4200 status 03/17/16 in transit!
Delivered 03/23/16
2SS Hyper Blue | 6M | NPP | Mag ride | ceramic white Int. | Black out bow ties | P3 Gauge| Front splitter. | 6 pot upgraded brembo brakes. | Magnuson Supercharger/95MM pulley | Rotofab Intake | ZL1 side skirts | HRE FF04 wheels - Michelin PSS4 | ZL1 add ons rock guards and lift points.
| AWE touring - resinated catback with link pipes.
oneredry is offline
Old 02-03-2016, 12:52 PM   #475
-Rooster-
Drives: 23 2SS 1LE
Again, this news regarding the 1LE reveal is directly from a GM spokesperson. It's not conjecture.
-Rooster- is offline
Old 02-03-2016, 01:21 PM   #476
ST1LE
ST1LE's Avatar
Drives: E92 BMW M3
Not possible.
ST1LE is offline
