#463 |
![]() ![]() ![]() ![]() Drives: Track prepped 2018 Camaro ZL1 (a10) Join Date: Aug 2013
Track: Vancouver Island Motorsports Circuit (B.C. Canada)
Elapsed Time= 1:25.60 Camaro Model = 2018 ZL1 Date= June 8th 2019 Tires= Stock factory Goodyear SC3 Mods= None https://youtu.be/rHxz2vGE9fc
2018 ZL1; Mag 2650 and 2 inch LT Headers , every SPL suspension upgrade, MCS 2 way coilovers, sway bars, square SC3R 325's all the way around, and multiple brake cooling upgrades
#464 |
Sorry wrong thread:(
#465 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2020 SS 1LE (previous: 2017 SS 1LE) Join Date: Mar 2012
#466 | |
aka BeastZL1
Drives: 2019 Camaro ZL1 1LE, 2004 Cobra Join Date: Dec 2017
Track (which config if applicable)= Charlotte Motors Speedway Roval (no bus stop)- Charlottee, NC
Elapsed Time= 1:26.43 Camaro Model = Camaro ZL1 2018 Date= June 2018 Tires= Goodyear Supercar 3's Mods= Race Alignment, SRF Brake Fluid, Factory Tires Lap at 6:50 mark, chasing JPDaughtery in his S2000.
#467 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 SS 1LE, 2016 1SS (previous) Join Date: Apr 2016
#468 |
![]() Drives: 2018 Camaro 2SS 1LE - Hyper Blue Join Date: Aug 2018
First ever HPDE so not too bad! Definitly see where I can shave many seconds off but a good first attempt at a new track, new car and new to the sport!
Track: Gingerman Raceway Elapsed Time: 1:48.00 Camaro Model: 2018 2SS 1LE Date: 6/17/19 Tires: Stock Mods: Stock, Castrol SRF DOT4, Track alignment |
#469 |
![]() ![]() ![]() ![]() ![]() Drives: 2013 C6Z06 Join Date: Nov 2016
Yep G3s. When I saw I was less than 0.2 off of Tomster's top time in a freaking ZLE on slicks on day 1, I wanted to beat it so bad. Then I did with that lap on day 2, I'm superpumped.
#470 | |
#471 | |
#472 | |||
![]() Drives: 2017 Camaro SS 1LE Join Date: Jun 2018
#473 | |
![]() Drives: 19' ZL1 1LE Join Date: Nov 2015
Cresson 1.7 CW Fast Laps
Track: Motorsports Ranch Cresson 1.7 CW
Elapsed time: 1:20.81 and 1.20.82 Date: 06/22/19 Camaro Model: ZL1 1LE Mods: ZERO (Stock) G3R |
#474 | |
![]() Drives: 2018 ZL1 1LE Join Date: May 2019
Track: Palm Beach Intl Speedway (PBIR)
Elapsed Time= 1:28.718 Camaro Model = 2018 ZL1 1LE Date= June 18th 2019 Tires= Stock tires, street alignment Mods= Rotofab Big Gulp intake, Kooks long tube catless headers, Corsa Extreme Exhaust. |
#475 | |
![]() Drives: '17 Camaro 1SS 1LE Join Date: Jun 2019
Circuit of the Americas
3-17-2019 2:35:96 Stock 2017 1SS 1LE |
#476 |
![]() ![]() ![]() Drives: 2016 2SS BLK A8 Vert Join Date: Dec 2017
Track = Mont Tremblant- Quebec, Canada
Elapsed Time= 1.50.175 (COMSCC Class Track Record, & 2nd fastest TT lap @ the event by only .48 sec margin) Camaro Model = 2016 SS (2/Vert) (Tech scale Wt 3,952 lbs w/driver) Date= 6/25/19 Tires= Hoosier R7's Mods= NPP Exhaust ran on Stealth this event, Lowered, FE4 Sways, Brake cooling ducts, UDP, CAI, Ported TB, Ported IM, E85, Headers, High Flow w/ secondary cat and crush pipe, and AFM valves deleted, some weight reduction, Track Alignment w/camber plates, Motul 600 brake fluid, Hawks... **Also added best practice run time** Date= 6/24/19 Elapsed Time= 1:51.218 Tires= GY SC3's, Same as above, And from signature...Lowered, FE4 Sways, E85 and Bolt-on's
