#4579 |
![]() Drives: MY17 2SS NFG Join Date: Jan 2018
Jeremiah 29:11
#4580 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Camaro 50th anniversary edition Join Date: May 2017
I removed my steering wheel and sent it to upholster. I will have a 12h Mark more defined thumb area and 5mm thicker.
Soleil
_____________________________________________ A car is fast enough, if you fear to unlock it in the morning." (Walter Roehrl) |
#4581 |
![]() Drives: 2017 1LT RS M6 Join Date: Jun 2017
Installed GM Blackout strip between taillights, 2018 model had it on and had to have it.
#4582 |
![]() Drives: 2000 GMPPSV SS & 2020 2SS Join Date: Jul 2017
#4583 |
![]() Drives: 2017 Chevy Camaro 2SS Join Date: Jan 2018
Added a tinted license plate cover
#4584 |
![]() ![]() ![]() Drives: 2016 2SS BLK A8 Vert Join Date: Dec 2017
Had to pull it out of the garage today, so got it a little dirty and took the pics on the stock wheel set-up with the new BMR's. Once the warmer weather comes I bet the springs will have settled a little more, AND it will look sooooo much better back on the new MRR's w/ SC 3's!!!
#4585 |
![]() Drives: 2016 2SS vert (wife's) Join Date: Jan 2018
Got her registered/licensed today. Bought a slim black frame for it and then had to go to three different places looking for some nylon screws. Some time since my last purchase of these, they stopped making the nuts with flanges. This means they don't cover the holes on either the plate of the frame. Finally found some that will work at O'Reilly's. What I do is install them at the bottom of the frame in reverse so the head is next to the body. I put some silicone on the heads so the body is protected, this also keeps it from rattling. I'll have to see what GM used for inserts for the attachment screws, I may have to cut a piece of rubber I have to put at the top of the plate so it doesn't abrade the paint.
#4586 | |
![]() ![]() ![]() ![]() Drives: 2018 1SS 1LE, 2015 RAM Ecodiesel Join Date: Oct 2017
#4587 |
New Scorpion hood is almost done. They just need to polish now.
2016 Camaro 2SS "Black Widow" |
#4588 |
![]() Drives: 2017 Camaro 2SS, Hyper Blue Join Date: Jan 2018
Looked at it while I started our snowblower to clear our driveway. Looked at it again while I parked the snowblower behind it and hope spring comes early to Wisconsin.
#4589 |
2018 SS 1LE Red Hot
Drives: 2018 SS 1LE Join Date: Dec 2017
Installed the Genuine GM Suede Console Lid with Performance Logo.
Here is a quick install video: https://youtu.be/KJLbQp5ZM4E
2018 SS 1LE Red Hot
https://www.youtube.com/lennyk |
#4590 |
![]() Drives: '17 2SS Vert H50, A8, F55, NPP Join Date: Jan 2018
Bought it. Got a 17 Fifty Anniversary convertible SS with auto, mrc and dme. Was a demo with just over 5k miles. When they say summer only tires, they mean it. Had a heck of a time getting up my 1 % grade concrete driveway due to a little slush.
#4591 | |
2018 ZL1 1LE
Drives: 2018 ZL1 1LE Join Date: Aug 2017
#4592 | |
