Old 06-16-2020, 10:22 AM   #407
AustinTXracer
Drives: 20 SS 1LE
Seems the 325 SC3 is out of stock everywhere now :(
John Hale
multi time solo nats runner up :(
AustinTXracer is offline   Reply With Quote
Old 06-16-2020, 01:19 PM   #408
AustinTXracer
Drives: 20 SS 1LE
You guys running race wheels and daily wheels, are you running TPMS in both? How do you swap the car over to the other set?
John Hale
Old 06-16-2020, 02:23 PM   #409
foshjowler
foshjowler's Avatar
Drives: 2017 Camaro 2.0T, 91 Miata
Only TPMS in the daily wheels, just didn't want to spend the money on them for wheels that are only on a few days at a time. To change the wheels I use a floor jack, impact wrench to save time/effort, and a torque wrench to get the lug nuts to spec.
305 BFG Rivals FTW
Youtube Channel
foshjowler is offline   Reply With Quote
Old 06-16-2020, 02:30 PM   #410
apexit53
apexit53's Avatar
Drives: 22 1SS 1LE Summit White
TPMS only on OE wheels. Just deal with the light on with the race set.
#53 F Street
2025 FS National Champion
2026 Sponsors
autocrossdigits.com
karcepts.com
Autocrossing Videos
https://www.youtube.com/channel/UCm-...3tiMt0KOg_2Aag
Instagram: apexit_53
apexit53 is offline   Reply With Quote
Old 06-16-2020, 02:50 PM   #411
Ummpwr
Drives: Honda S2000
I bought a set of 4 Tpms sensors on eBay for $50 total. I use them in my 19in autox wheels to try the out and they have been working for the last 7mo. Also bought the tpms relearn tool on eBay for under $10
Ummpwr is offline   Reply With Quote
Old 06-16-2020, 03:31 PM   #412
AustinTXracer
Drives: 20 SS 1LE
So then I guess the car doesn't actually need TPMS to operate correctly. No limp mode or TC/ESC related issues? If not, great!
John Hale
Old 06-16-2020, 04:27 PM   #413
rotis
rotis's Avatar
Drives: 2019 ZL1 1LE
If the car gets valid readings from all 4 sensors, you're good.
If it sees that there are 0 sensors, you're good.
If it sees 1-3 sensors, you have a TPMS fault and it will not permit you to disable stabilitrac.
rotis is offline   Reply With Quote
Old 06-17-2020, 07:14 AM   #414
apexit53
apexit53's Avatar
This!
its all or nothing lol
#53 F Street
2026 Sponsors
autocrossdigits.com
karcepts.com
Autocrossing Videos
Old 06-28-2020, 10:27 PM   #415
apexit53
apexit53's Avatar
Videos from this weekends events. Need to work on the camera angle so you can see out of it better.... in a 6th get easier said than done lol
Day one was drying conditions, two slower areas had puddles on turn in still, but we made the most of it.
Day 2 was all dry, car felt good, messed up a but in the slalom but overall enough to take top pax
#53 F Street
2026 Sponsors
autocrossdigits.com
karcepts.com
Autocrossing Videos
Old 06-28-2020, 10:33 PM   #416
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
After long hiatus for.. reasons! We're back, slowly and carefully exercising our old tires. Due to camera malfunction.. err user error, there was only shot of my hand turning it on.. 7 times. Apparently time lapse mode does not reset to video mode when you power cycle the camera.. good and bad i guess. There a awesome curse laden tank slapper recorded on the PDR.
ing for grip.
http://www.motorsportsne.com/
Old 06-29-2020, 11:00 AM   #417
rotis
rotis's Avatar
Last weekend in Packwood, car is feeling great after a few setup tweaks.
Day 1, was 2nd in overall PAX-
Day 2, our club only scores the first 3 runs but I forgot to turn off traction control on my 3rd run. This was my 4th run, which was top PAX -
Old 06-29-2020, 02:11 PM   #418
5inn
5inn's Avatar
Drives: N/A
Are you using a headrest mount for this view?
'17 SS 1LE.
5inn is offline   Reply With Quote
Old 06-29-2020, 04:12 PM   #419
apexit53
apexit53's Avatar
yeah, just need to raise the seat up or something.
#53 F Street
2026 Sponsors
autocrossdigits.com
karcepts.com
Autocrossing Videos
Old 06-30-2020, 07:01 AM   #420
5inn
5inn's Avatar
Drives: N/A
For sure. I'd also recommend changing your GoPro metering mode to 'spot', if you haven't already. When you mount it anywhere with an inside view of the car, the camera usually meters for the inside which causes the outside to be a bit overexposed.
I was trying to find an example on one of my videos. I think the best one is this one of my friend spinning my old '17 Si. It's bright and sunny outside but can see well, while inside is a bit dark, but still plenty usable.
'17 SS 1LE.
