Old 12-16-2017, 09:25 PM   #407
PackersFan26
PackersFan26's Avatar
Drives: 2017 Summit White 2SS
Hey ted,
Is there any way to tune in more aggressive pops and crackles? May sound silly but I love the sound
Follow me on IG: @lip_stick.ss
PackersFan26 is offline   Reply With Quote
Old 12-18-2017, 06:05 AM   #408
JANNETTYRACING
JANNETTYRACING's Avatar
Originally Posted by pbm6gto View Post
Ted,
What is the max of the heartbeat? Should one go heartbeat or D1X? M6 car roll racing and 1/4 mile fun runs and still daily? I'm going to start out from a bone stock car and over time we all want more so I want room to grow with the blower not maxing out.
Thanks for your input.
We can only estimate no on has maxed one out, we know it will easily do 900 RWHP as I have personally made 850RWHP below max blower speed.
Choice of supercharger is a personal choice Either one will do a great job.
You will hit fuel delivery and octane limits long before you max out either blower.
Ted.
www.jannettyracing.com
email tedj@jannettyracing.com
Old 12-19-2017, 02:35 PM   #409
carlosgrana
Drives: 2016 camaro ss
What boost a pump kit do you recommend for 700whp on pump gas.
i currently have lt4 system and zl1 in tank pump.
carlosgrana is offline   Reply With Quote
Old 12-19-2017, 03:24 PM   #410
JANNETTYRACING
Our JMS fuel pump voltage booster in stock please call to order 203-753-7223
Old 12-19-2017, 08:49 PM   #411
SilverSS1LE
SilverSS1LE's Avatar
Drives: 2017 Summit White 2SS A8
What fuel system are out to support 800+ for the cars. From what I've seen the stock LT4 high pressure and injectors start to fall off just short of that correct ted?
Mod List: Stock (for now)
SilverSS1LE is offline   Reply With Quote
Old 12-20-2017, 12:56 AM   #412
gippy87
Drives: 2016 2ss
Not a question for janetty but in response to the last post im curious if the new c7 zr1 port injection system will be adaptable to our LT1's as a factory solution to our fueling needs
gippy87 is offline   Reply With Quote
Old 12-20-2017, 07:43 AM   #413
JANNETTYRACING
It is about there yes.
Race gas may be able to stretch that just a tad.
Old 12-26-2017, 10:31 AM   #414
steelheadrob
Tactical Garage
steelheadrob's Avatar
Ted,
I see in your maggie packages on your website you use the JMS fuel pump voltage booster instead of the ZL1 intake pump. If your a not planning on doing any thing to the high side fuel does the JMS get you any additional HP over the ZL1 pump? Any other advantages of one of the other?
Thanks
steelheadrob is offline   Reply With Quote
Old 12-28-2017, 09:06 AM   #415
JANNETTYRACING
Originally Posted by steelheadrob View Post
Ted,
Thanks
We are building a new web site so stay tuned for more details.
The desired HP determines what we include in our packages.
The low side pump does not extend the range of the High pressure pump and injectors they both have hard limits.
On the other hand if the low side pump does not maintain pressure it can reduce that hard limit of the high pressure system.
The voltage delivery to the low side pump is an issue easily resolved by the JMS fuel pump voltage booster, weather you run the stock low side pump or ZL-1 low side pump.
If you follow our builds on Facebook you will see what we are doing in different builds at different power levels.
Ted.
Old 12-28-2017, 11:26 AM   #416
steelheadrob
Tactical Garage
Ted.
Just to make sure I understand. I thought typically the low side ran out of fuel first and that it could be addressed by either with a Zl-1 lowside pump or the JMS fuel pump voltage booster. Is that correct assuming the lowside is not maintaining pressure or is the JMS addressing a different issue from the ZL-1 pump?
Thanks for the education.
Old 12-28-2017, 01:17 PM   #417
JANNETTYRACING
The JMS addresses the system voltage problem which will maximize any existing pump to it's full potential.
Again it will not extend the range of the high pressure system.
But in the event of very low, low side pressure you could reduce the range of the high side system.
The ZL-1 pump is larger than the Standard SS pump.
Ted.
Old 01-06-2018, 12:14 PM   #418
oneredry
HYPER SS
oneredry's Avatar
Drives: 2016 Supercharged 2SS
Hey Ted, I've always listed to what you had to say and did just that. So first off I want to thank you for being a excellent contributor to our forums. that said, could you take a look at a thread I made just under this one? it seemed to have channeled off with out any type of answer. would you mind putting in your advice? Thanks in advance
http://www.camaro6.com/forums/showthread.php?t=517276
Ordered: 1/15/2016
2000 status 02/01/16
3000 status 02/29/16
3400 status 03/07/16 TPW of 03/14/16
4200 status 03/17/16 in transit!
Delivered 03/23/16
2SS Hyper Blue | 6M | NPP | Mag ride | ceramic white Int. | Black out bow ties | P3 Gauge| Front splitter. | 6 pot upgraded brembo brakes. | Magnuson Supercharger/95MM pulley | Rotofab Intake | ZL1 side skirts | HRE FF04 wheels - Michelin PSS4 | ZL1 add ons rock guards and lift points.
| AWE touring - resinated catback with link pipes.
oneredry is offline   Reply With Quote
Old 01-08-2018, 09:50 AM   #419
JANNETTYRACING
We appreciate your support, I am always glad to help.
Old 01-09-2018, 08:08 AM   #420
ThatRedFirebird
Drives: 2002 Pontiac T/Am, 2016 Camaro 2SS
Hey Ted - just curious if you guys have ever weighed the various S/C systems available. I'm curious which one would be the lightest while still be robust enough to drive daily.
I know this is a very general question but I'm also wondering if any of the systems are significantly different in weight, like more than 50 pounds apart (and compared to an LT4 OEM style setup).
ThatRedFirebird is offline   Reply With Quote
