#29 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2020 Camaro 2SS A10 Join Date: Jun 2018
My bad thought they were all season
Maybe I'm confusing them with the AZ850's then but one of them has bad reviews... don't remember which.
#30 | |
#31 | |
Thanks for the response! I have read a lot about the wire harness can get in the way and it seems to be quite the pricey fix lol. I'm hoping to be able to get the new set up within the next month or two so I can be ready for summer. Thanks for all the help I'm prob gonna post an update once I cash out on a nice set. |
#32 | |
#33 | |
#34 |
Tire prices have gone berserk lately... well, as an alternative, you can do something else that will still be helpful, namely you can go with the slightly cheaper Conti ECS 02 tires in a staggered setup of 255/40/20 front, 285/35/20 rear.
First, this will work with stock SS wheels that you can buy really cheap, and if you want to save even more, you can technically keep your 8.5" wide LT1 front wheels and only buy two 9.5" SS wheels, although I'm not sure if the same wheel design is available in this size---I'd probably just buy a full stock SS set of wheels off someone here in the forums. The speedo will be very slightly off, but you probably won't even notice. Second, you'll still have much better and quieter tires, basically most of the advantages I listed, except your dry traction will be somewhat lower and you won't have the killer looking 305 or 315 steamrollers in the rear. However, you'll save at least a thousand if not more compared to an SS 1LE wheels + PS4S tires combo. Your car, your money we just highlight some options for you to choose from.One final word of caution if you go with 285/35/20 in the *front* as someone suggested: they're going to be extremely close to the wheel well when turning the steering wheel to full left lock on the driver and full right lock on the passenger side. I ran this setup with PS4S tires for a while, and the driver side tire did actually rub the liner (in a place with a hard metal part behind it), not too much, but enough for the wear to be visible. Not a dealbreaker IMO and each manufacturer's tire sizes are physically different even for the same nominal sizes (go figure, sheesh), just wanted to make sure you're aware.
