#29 |
![]() Drives: Chevy Camaro Join Date: Sep 2022
I’m thinking more of the rule of thumb like nitrous. Best NA timing and pull a degree for every 50hp of nitrous or 1lb of boost in this case.
'20 Camaro LT1
Twin 67/62 turbo 401(L8t) Texas speed forged piston & rod, BTR stg1 turbo cam, holley ultra lo, port injection, circle d 3600 stall, et street r’s on racestar recluse wheels. 1.33 3.75 5.75@122.98 1/8 pb 9.04@141 1/4 pb technically '94 Camaro Z28 6mt cc306 cam, 4:10's, longtubes with x pipe, otr intake |
#30 |
![]() Drives: Chevrolet Camaro Join Date: Apr 2022
Yep, this was 93 octane street stuff though. Would've had to re-evaluate our strategy for built engines on race gas/E85 running 30 psi.
Procharger P1X, CSP Big Boy Cam, CSP Headers, LT5 Throttle Body, MSD Intake, LT4 HPFP, LT4 Injectors, JMS BAP, 93 + Boostane - 750+WHP
#31 | |
I agree with this to some degree especially when referencing pump gas, but it's still sort of a blanket statement. Coming from my NA LT1 that had 28 degrees of timing on E85, I now run 20 degrees @ 10 psi of boost with E60. Been this way since 2019 still going strong. On pump gas I would have had to pull 16 degrees of timing. I have tuned other LT1 based 6th gens that were forged, 1 pt lower compression, and run 22-24 degrees of timing on 12-15psi of boost with E50-60 fuel...no issue with a 7-heat range plug LT4 is 1.5 point lower in compression, and they are perfectly fine at stock timing (24 degrees) or slightly above on E60 with 16-18 psi making 3-400hp over stock. Moral of the story, there are too many variables (compression, fuel, engine efficiency) to simply say pull X amount of timing per 1psi of boost. The best thing you can do when making a lot more power vs stock is to start with conservative timing, read the plugs, and creep up on timing until the timing mark on the ground strap is in an ideal range.
#32 | |
Drives: Camaro ZL1 Join Date: Oct 2025
#33 |
Yeah, that could be... Dyno numbers sell parts and promote business. Some shops will also put all the timing in it to make a number and pull it back out before giving it to the customer. Regardless I don't believe there are any standards anymore. I was just pointing out that those "rule of thumbs" don't always line up with every combination.
#34 | |
#35 | |
Moderator
#36 |
![]() ![]() Drives: 2015 Camaro ZL1 Join Date: Oct 2020
It's all about knowing when to say when based on experience and the specific combination of parts.
Just because it will take a certain number doesn't mean it wants it. |
#37 | |
'20 Camaro LT1
#38 | |
Super Stock
Drives: Chevrolet Camaro ZL1 Join Date: May 2022
758 HP/ 804 TQ |
#39 |
Snackbar Tuning
Drives: 2023 SGM ZL1 Join Date: Oct 2016
LT4's will actually respond to more timing above 6000 RPM. Look at how the Blackwings are tuned from the factory.
But King LT1 and Katech_Mike have already shared definitive facts. Essentially it all depends. lol
GM Gen V Calibrator
#40 |
Super Stock
This statement is very true. I've found the same as well without even knowing about the Blackwings.
758 HP/ 804 TQ |
#41 |
I discussed the spark advance topic with a nationally known LT4 tuner last week and was surprised to find out that he uses 22° of advance, which is what my current tuner is aiming for, I believe. On the other hand, numerous tuners have informed me that they use 23 to 24°. Perhaps it depends on the specific build.
2020 ZL1LE A10.
LME LT4 390 short block, LME CID Heads, Kong E2650, FBO. 15" conversion, MT ET Street R 325/15. 100 octane: 1045hp/1055tq. 100 octane + Meth (1x10+): 1117 hp/1067 tq |
#42 | |
