Old 06-19-2025, 11:23 AM   #29
JSH
JSH's Avatar
Drives: '20 ZLE
We're taking the engine apart. It's blowing coolant out of the Moroso, as well as oil out of the crankcase. I hope it's only a gasket.
2020 ZL1LE A10.
100 octane: 1045hp/1055tq.
Old 06-19-2025, 11:25 AM   #30
clg82
Drives: 2020 Camaro ZL1
We're taking the engine apart. It's blowing coolant out of the Moroso, as well as oil out of the crankcase. I hope it's only a gasket. It's not sleeved, so that's not it.
Damn man, sorry to hear that!
Old 06-20-2025, 05:53 AM   #31
Megahurtz
Snackbar Tuning
Megahurtz's Avatar
Drives: 2023 SGM ZL1
ah dang, think we went too spicy on timing?
GM Gen V Calibrator
Old 06-20-2025, 10:53 AM   #32
JSH
JSH's Avatar
Drives: '20 ZLE
My shop says that 24 degrees is not a lot of timing, but it definitely got too hot due to not enough fuel or meth because about a 1/4" of the ground strap was burned off
2020 ZL1LE A10.
Old 06-20-2025, 11:06 AM   #33
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
What plugs are you running?
Old 06-20-2025, 12:09 PM   #34
JSH
JSH's Avatar
Drives: '20 ZLE
They were NGK 6510 gapped at 24-26, last I heard, but I'll ask him
2020 ZL1LE A10.
Old 06-20-2025, 01:07 PM   #35
Joshinator99
Moderator
Need a better plug at your power level. My buddy’s 1K WHP Coyote nuked a 6510 his last time out too…melted the ground strap right off. Take a look at Brisk Silver.
Old 06-20-2025, 01:44 PM   #36
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
I would run a 8 heat range plug for your power imo. Brisk RR12 or something equivalent
Old 06-20-2025, 06:16 PM   #37
JSH
JSH's Avatar
Drives: '20 ZLE
Don't I want the modified, projected tip, RR08S? This is the coldest I've seen. The 6510 is HR 07. The NGK 6509 LTR6IX-11 Iridium IX Spark Plug is HR 06.
RR08S Brisk Racing Silver Spark Plug
Brisk SKU - RR08S
Parameters:
Thread Diameter 14mm
Thread Reach 25mm-1"
Hexagon 16mm-5/8"
Seat Type Tapered
Design Silver Racing
Resistor Yes
Projected No
Heat Range - 08
2020 ZL1LE A10.
Old 06-20-2025, 09:36 PM   #38
Joshinator99
Moderator
Brisk SKU - RR08S
Parameters:
Hexagon 16mm-5/8"
Seat Type Tapered
Resistor Yes
Projected No
Heat Range - 08
You want RR12S at a minimum which is a heat range colder than the 6510. I just did RR10S which is an another step colder than that and hope to have some hard runs to test them out soon. Early testing looks good.
Old 06-21-2025, 07:12 AM   #39
Megahurtz
Snackbar Tuning
Megahurtz's Avatar
Which cylinder(s) had the strap partially missing? If not all of them I would point to inconsistent meth distribution. Maybe its time to go port and run Ethanol
All of the logs I saw had good Lambda but I do recall some times it would be lean for a moment which was likely the meth delay. I do recall we also ran on low boost with a no meth tune. I'm just trying to think when could this have happened. Pretty sure you checked the plugs recently so this had to have happened recently as well?
either way....lets put it in Atlas port and E85. Sunoco can deliver a 55 gallon drum of E85R
PS we have run the LTR7IX on cars up to a little over 900 wheel but they get changed often and these cars run Meth plus E75. Race gas plus meth won't keep things as cool so yeah I agree with the guys above that its time to put in some colder plugs.
GM Gen V Calibrator
Old 06-21-2025, 07:46 AM   #40
JSH
JSH's Avatar
Drives: '20 ZLE
RR12S Brisk Racing Silver Spark Plug is HR 12, while NGK 6509 LTR6IX-11 Iridium IX Spark Plug is HR 06.
2020 ZL1LE A10.
Old 06-21-2025, 07:47 AM   #41
JSH
JSH's Avatar
Drives: '20 ZLE
I'm now thinking race gas-only.
2020 ZL1LE A10.
Old 06-21-2025, 09:07 AM   #42
Joshinator99
Moderator
Not comparable, NGK and Brisk use different heat ranges. Lower number with Brisk is colder and NGK is the opposite. My recommendation above is correct.
