#29 |
![]() Drives: 17 hyper blue 2SS M6 Join Date: Mar 2018
Alright well all the repairs and upgrades are completed finally.
After my son spun the car off the track in September I had a lot of repairs to make and took that opportunity to do a couple upgrades. The right side aux radiator was damaged so I took the left side and moved it over to the right, replaced the factory oil cooler with the pwr cooler and installed used improved racings thermostat and plate. A+ stuff from both companies, excited to see the oil temps drop the claimed 50 degrees. I convinced my wife I needed to spend ridiculous money on shocks that I didn't really need to, enter the MCS 2 way remote coilovers. I ended up with an alignment at 3.6 degrees camber up front, 2.5 rear. Zero toe on front and 1/32 toe in for the rear. The ride height is higher than before, but now I can fit a jack under the car, kinda. The jack hits the side skirts but I can get it under the car. Should help with loading the car onto the trailer and less scraping on Lagunas corkscrew. I'll be starting with all the settings in the middle, sway bars and compression/rebound. The spring are 800lb front and 1100 rear. About 30% stiffer than my last set. The splitter I made is 1/2 maple plywood. I skipped the splitter tunnels for now because the ones I bought were just a little too long for my liking, I'll keep shopping for some but for now it's just a flat bottom. I used Hartman's kit to mount it and it worked out pretty well. Overall it's pretty good, not perfect but good enough. It's angled down about 1.3 degrees and extends 4 1/2" from the air dam. Test day Tuesday at Thunderhill East, hopefully everything is good to go so when I tow it to COTA end of May there are no concerns. |
#30 | |
![]() Drives: SS 1LE Join Date: Aug 2024
#31 |
I'm sure it would have been fine, as this is how they ship them to everyone. I did install the helpers, for my own piece of mind. I got the alignment specs I wanted with plenty of clearance for the 315/30/18 tire.
#32 |
![]() ![]() Drives: 2020 SS 1LE Join Date: Aug 2020
Looking great Mark! Ready to trade blows with you soon!
#33 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 1ss camaro Join Date: Feb 2016
the boing sound when u lift it and lower is down is alarming lol but doesnt hurt anything no helper springs on my mcs 1 way setup
#34 | |
![]() ![]() ![]() ![]() Drives: 2020 ZL1 1LE Join Date: Sep 2012
Also you need a breaker bar on the front upper strut bolts (2 of them per side) to keep them from loosening up. Torque with the breaker bar till they stop.
#35 | |
![]() Drives: '22 2SS 1LE Join Date: Nov 2023
#36 | |
I actually installed helper springs, and now the perch sits below the top of the tire. There's still enough but not a lot of clearance between the perch and the tire. Running 315's, 1 inch spacers and 3 degrees of camber. |
#37 |
Baddawg53, I have a very similar setup as you, suspension, aero, engine, etc. How did you run at COTA? I was last their on May 10-11
Mods: MSD, Headers, 95mm TB, high flow cats, full 3" exhaust, SPL, MCS 2-way remotes, sway bars, rear diff lock outs, Sparco racing seats, 6 point harness, CMS roll bar, Nine lives wing, 6" splitter, ACS canards.
www.youtube.com/@Racer_Mike87 |
#38 | |
The car handled fantastic, especially through the esses. Few issues with a fuel pressure fault code and I think I boiled the clutch fluid (mid day on Sunday clutch wouldn't disengage) but overall super happy. |
#39 | |
www.youtube.com/@Racer_Mike87 Last edited by carguy55; 06-15-2025 at 10:39 AM. |
#40 | |
I'm curious what you landed on for your shock settings? I'm at 12 compression 8 rebound for the front and 9C and 8R for the rear. I was starting to get a little understeer around 18 into 19 towards the end, I know the tires were starting to fall off a little, but I might need to adjust the shocks slightly. Also I need to secure my reservoirs with those clamps like you have there!! The zip ties are kinda ridiculous. My car is kind of ridiculous, but I love it. I even deleted the sunroof!! If I had known what it would turn into back in 2017 I would have ordered the 1SS 1le rather than the 2SS non 1le, but hindsight is always 20/20. |
#41 |
Agreed, 2:27 was a great first time outing! Wish we had another day and one with zero gremlins. I’m sure you would’ve had your 25! I didn’t even get to ride passenger with you!
#42 | |
Your laps were damn good for a completely stock (essentially, besides the wang) car, damn near Randy's. Why haven't you posted it yet? |
