Old 04-07-2025, 11:20 AM   #29
jamess1le
Drives: 2018 2ss 1le
lol
jamess1le is offline   Reply With Quote
Old 04-07-2025, 11:55 AM   #30
Bad Anvil Garage
Bad Anvil Garage's Avatar
Drives: 2000 GMPPSV SS & 2020 2SS
I'm buying a set of Pilot Sport 4S for my OE 1LE rims. Found out using a tire comparison calculator that 315/30R20 are about as close as it gets to the original SS 275/35R20 so my speedo will be as accurate as can be... plus I get a little more tire out back. Nice!
Also, check with your Chevy dealers if you're in the market for tires. My local dealer here in Indy has a BUY 3, GET ONE FOR $1. Can't beat that!
Bad Anvil Garage is offline   Reply With Quote
Old 04-07-2025, 01:10 PM   #31
275/35/20 front and 315/30/20 rear is the tire sweet spot for our non-1LE SS models with 1LE bits, including wheels. I'm running this exact size combo with PS4S rubber, and it's perfect.
Old 04-08-2025, 07:39 AM   #32
Bad Anvil Garage
I'm going with 285/30R20 on the front.
Old 04-08-2025, 08:11 AM   #33
Risky business Let us know if it worked flawlessly, though.
Old 04-08-2025, 08:48 AM   #34
Bad Anvil Garage
That's the original OEM size for the 1LE GY SC3 I have now. Ran them with no issues, even on my lowered car. I'm just changing from 305/30/20 on the rears to 315/30/20 because that's actually closer to the original 2SS 275/35/20 diameter. I get a tad more width and more accuracy on my speedo/odo.
Old 04-11-2025, 01:33 PM   #35
Bad Anvil Garage
New Michelin PS4S ready to go on the car tonight. 285/30R20 & 315/30R20. Will be changing the pads to Power Stop Z26 while I'm at it. BTW, if y'all aren't using Dura-Coating tire dressing yet, you need to. Zero sling, no gooey slime, dry to the touch, lasts for months!
Old 04-11-2025, 07:57 PM   #36
speedyink1
speedyink1's Avatar
Drives: 2023 Camaro 1SS 1LE 6MT
These pads are in my future! There's tons of life on my stock pads still, but I dream of the day I don't have to deal with as much dust!
speedyink1 is offline   Reply With Quote
Old 04-11-2025, 11:08 PM   #37
2SS Capt
2020 Shadow Gray 2SS
2SS Capt's Avatar
Just do it, I changed my pads at like 400 miles, the stock pad dust is ridiculous! Unless you are tracking your car, the Z26 pads are just fine...
Old 04-14-2025, 07:15 AM   #38
Bad Anvil Garage
UPDATE: The look and fit is great. I might add 5mm spacers on the rears to get them to poke just a bit more to get closer to matching the poke on the fronts.
