Old 05-30-2025, 06:36 AM   #29
nighttowl
Sarcasm loading --------
nighttowl's Avatar
Drives: 2018 ZL1 1LE
Which recall is that? All I'm aware of is the crankshaft issue that they recommend to patch up by using 0W-40 oil, and the A10 recall due to bad valve bodies.
Your right - Looks like the info I had read was wrong.
2018 MBM ZL1 1LE - 652 rwhp, 588 rwtq SAE
2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD
2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD
nighttowl is offline   Reply With Quote
Old 05-30-2025, 07:51 PM   #30
george
ZL1 Driver
george's Avatar
Drives: Camaro ZL1 & BMW M3/E92
It's not a safety issue or there would have been a recall. Typically you get a warning light letting you know your oil pressure has dropped. You have time to get out of traffic. Some people still drive them short periods even after the light although they shouldn't.
Tell that to the gentleman I spoke to at a car show who had his '18 ZL1 engine oil pump fail on the turnpike and engine seized. Happened very suddenly with little warning.
george is offline   Reply With Quote
Old 05-31-2025, 06:28 AM   #31
Z OH 6
Drives: 2024 CT5-V Blackwing
I can tell it to anyone, but then again you could say a tire blowout is a safety issue too but they aren't recalling cars to replace them with solid rubber tires. These one-off scenarios are outliers and not the norm. It's not a safety issue as deemed by GM and the National Highway Traffic Safety Administration. Even if the oil pump failed, the engine would not seize immediately, the driver would have had to ignore the low oil pressure indicator or would have been hot dogging the Hell out of it at high rpm when it happened. You likely don't know all the facts behind that story and people aren't very honest with these stories when they're pissed about it.
Old 05-31-2025, 06:32 AM   #32
Z OH 6
Originally Posted by nighttowl View Post
Yet the chevy trucks are being recalled for bad oil pumps?
Totally separate issue. Not related to oil pumps and the issue can cause the engine to completely fail likely without warning unlike the oil pump issue being discussed here which often gives plenty of warning. People choose to ignore the warning are those that end up with blown engines.
Old 05-31-2025, 11:23 AM   #33
ZLRob
Super Stock
ZLRob's Avatar
Drives: Chevrolet Camaro ZL1
The crankshaft issue is occuring because the engine is eating itself up on the inside from the original recommendation of using 0-20 oil on the 6.2's and they recommend using 0-40 as a solution. Apparently the solution has been working. There are two fixes for the issue. One involves getting the engine replaced and then running original oil recommendations and the other involves just switching to 0-40 if they deem your engine is still okay.
758 HP/ 804 TQ
