Old 07-15-2024, 09:06 PM   #29
N Camarolina
N Camarolina's Avatar
Drives: 2021 2SS 1LE
Originally Posted by USMUCL View Post
You’re not the first person to tell me this is not unusual and, perhaps, nothing to be terrible concerned about.
Another told me it is common for Sport 1 to burn up the brakes once you approach a certain speed/level.
I'm not seeing that on my tracked, OEM setup, 1LE and I drive in Sport 1.
I have the PDR and I look at the data to see if I'm activating the ESC (my goal is to drive just beneath the level of activation or only have it activate on corner in situations when I'm happy with the amount of yaw but the ESC programming thinks it's too much). If you are driving smoothly, ESC would be activated either by very aggressive trail braking (see previous sentence) or by the tail stepping out under corner exit acceleration (Sport 1 generally doesn't permit enough throttle to allow this).
I would think that in order to have the ESC activating frequently enough to cook the brakes, you'd have to be making frequent abrupt inputs that upset balance and induce oversteer, purposeful or otherwise. Any chance you were doing that in the session where you had the problem?
N Camarolina is offline   Reply With Quote
Old 07-16-2024, 07:30 AM   #30
m6-lt1
m6-lt1's Avatar
Drives: 2023 Chevrolet Camaro 2SS 1LE
Originally Posted by DaveC113 View Post
Slightly OT but related, what are folks using for caliper rebuild kits?
https://amzn.to/3DPVnSY
These are the vented pistons so they are an upgrade. You would have to order 2 kits I believe.
You also need to order the dust boots separately.
Current: iso GT500
Prior:
2023 Camaro 2SS 1LE
2016 Camaro 1SS
2007 Mustang GT
2008 Civic Si
m6-lt1 is offline   Reply With Quote
Old 07-16-2024, 08:42 AM   #31
DaveC113
DaveC113's Avatar
Drives: 2018 Camaro 1SS 1LE
Thanks!
Old 07-16-2024, 09:36 AM   #32
Slurpee
Slurpee's Avatar
Drives: 2020 ZL1 A10; Shadow Gray Metallic
I am running a full Racing Brake vented kit front and rear. The pistons are a single stainless steel piece vs the GM being 2 pieces. The high temp silicone boots don't seem to be worth it. Either I messed up the install and got brake lube on the seals, tore them with the picks, or I got a bad batch. Some boots crumbled after a couple of track days. My upcoming rebuild I am trying out the stoptech silicone seals at a fraction of the cost.
Slurpee is offline   Reply With Quote
Old 07-16-2024, 03:51 PM   #33
Christian1LE
Drives: 2004 BMW 330CI, 2022 1SS 1LE
My high temp dust boots up front have worked great. Over 1 year on them and they still look like new. I'm rebuilding everything soon but I do plan on getting the high temp ones again.
The OEM dust boots get cooked after a few weekends, not even worth installing IMO.
Christian1LE is offline   Reply With Quote
Old 07-17-2024, 08:34 AM   #34
Slurpee
Slurpee's Avatar
Must be an installation error on my end then. How do you install the dust boots? My last rebuild I had the pistons halfway extended when putting them on, then pushed them all in. I suspect the green brake grease provided came in contact with the boots as I was pushing them in and that's why they crumbled.
Old 07-17-2024, 09:06 AM   #35
USMUCL
Drives: 2021 Camaro 1SS 1LE
What vented kit did you use?
USMUCL is offline   Reply With Quote
Old 07-17-2024, 09:41 AM   #36
Christian1LE
When I installed them I didn't do a rebuild. I just removed the crumbled OEM ones and slipped on the high temp ones.
Old 07-17-2024, 09:42 AM   #37
USMUCL
Can you link the high temp boots you used?
Old 07-19-2024, 08:33 AM   #38
Christian1LE
https://racingbrake.com/bc-61bs/ (front)
https://racingbrake.com/c7-42bs/ (rear)
make sure you select "High temp"
Old 07-19-2024, 09:10 AM   #39
Slurpee
Slurpee's Avatar
https://racingbrake.com/camaro-7/
Select the appropriate caliper and they will have a full kit, pistons, seals, and boots
Old 07-19-2024, 07:08 PM   #40
USMUCL
Any reason to choose those pistons over the less expensive GM vented piston kit (23242510)?
