#29 |
![]() ![]() ![]() ![]() ![]() Drives: '23 1SS Sharkskin A10 Join Date: Sep 2018
I just tuned my car. Baseline hp on the dyno was 391. I got a 44 whp bump with headers/cats/Rotofab and e50. To get a 80 whp with just those simple bolt ones is very impressive!
Kooks 1-7/8" Long Tube Headers l Kooks Hi-Flow Cats l Kooks X-Pipe l Borla S-Type NPP Exhaust
Rotofab CAI l Mishimoto Catch Can l DSX Flex Fuel Sensor l 93/E85 Tune l GM Lowering Kit Ported LT2 Intake Manifold l Ported 95mm LT5 TB l BMR Rear Cradle Lockout Kit Halo Tunnel Brace l MRR 1LE Wheels l Goodyear SC3 1LE Tire Package l 480whp/467wtq |
#30 |
Moderator
44 WHP sounds very realistic.
#31 |
I think you posted before finishing your coffee.
#32 |
Agreed Josh. What's even better, is that I gained 60+ torque
#33 |
Since OP didn't specify price as a factor..."there's no replacement for displacement".
At the current price point of mods, I'm planning to go with a bigger motor. |
#34 |
Just saying, but forced induction is very much like adding displacement, especially when using a positive displacement supercharger like the Maggie or the Whipple. Probably cheaper than a brand new 416 or 427 setup, even with the necessary fueling mods.
735 rwhp | 665 rwtq Magnuson TVS 2300 80mm pulley | Kooks 1 7/8" LT headers | JRE smooth idle terminator cam | LT4 FS & injectors | TSP forged pistons & rods JMS PowerMAX | DSX flex fuel kit | Roto-Fab CAI | Soler 95mm LT5 TB | 1LE wheels | 1LE brakes | BMR rear cradle lockout | JRE custom tune 1100 - 1/30/18 | 2000 - 1/31/18 3000 - 2/06/18 TPW 2/26/18 3400 - 2/19/18 | 3800 - 2/26/18 4300 - 2/27/18 | 4B00 - 3/01/18 4200 - 3/05/18 | 4800 - 3/14/18 5000 - 3/16/18 | 6000 - 3/19/18 Last edited by arpad_m; 11-11-2024 at 11:03 PM. Reason: if only I could type |
#35 |
Moderator
Agreed, and adding displacement will probably only get you an extra 40 cubic inches or so before you max out what an LT block can do. Not much bang for the buck. On the other hand, a supercharger will let you essentially double engine size for every 14.7 PSI you can feed into it… no touching that kind of power addition using just engine displacement.
#36 |
2020 Shadow Gray 2SS
Not a modder, but from things I have read it almost sounds like E85 and an LT2 intake (with tune) would get you about another 100 HP (maybe not to the wheels but to the crank which would likely be an additional extra 90whp)...
Just my thought from the outside looking in, I would think this could easily be done for under $1,000....
After delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Pedals, SS Wheel Caps, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF-Full Front & Rockers, 35% Tint, CeramicPro coated, RST Stainless Brake Lines, Castrol SRF, MSD Plug Wires, Mamo V3 Ported TB Left: My "fun" ride (455 HP). Right: My "work" ride (52,000 HP): a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph. BOTH AWESOME to operate... |
#37 |
Moderator
No way…. Probably 30-35 WHP gain tops on a stock SS for those 2 mods.
#38 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: like an old lady Join Date: Jun 2012
100+ crank will be several thousand dollars. i had basically every bolt on available by the time i sold the car.
2" headers full 3" exhaust mamo ported msd intake manifold stock LT5 tb modified rotofab dry ati damper ethanol sensor CAPABLE TUNE(R) 2018 1ss 1LE. my car picked up 10 mph from stock to modded. im not the best driver in the world, but i am no slouch. lots of testing and data logging. in a 4 yr span, the car was dyno tuned then street verified twice. updated the tune once after that. the tuner (and driver) will make the difference in how the car performs. id say that is 100 crank in a car with a 3900+ lb raceweight. i drove that car all over the western side of the country. sat in traffic for hours on 100* days, picked my daughter up from school and let my 70+ yo parents take it out. drove like stock with stock reliability. very easy to install bolt on parts. tough to beat no matter the cost.
#39 | |
#40 | |
Moderator
E85 is great and will shine in letting you keep full power even when it’s hot out or you hot lap the car, so that’s the big benefit on a stock LT1. On a stock LT4 that becomes even more important. As you turn up the power the E85 cooling & octane is a lifesaver. When I was making a couple of hundred HP less, I dynoed my car on straight 93 and got 837 WHP. We put it to E50 and went to 927 WHP with no other changes. At my current power level I suspect it’s over 100 WHP difference.
#41 | |
#42 | |
Moderator
