#29 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2024 CT5-V Blackwing Join Date: Sep 2020
EDIT: 315/35/20 will not work, 315/30/20 will work. Last edited by Z OH 6; 06-05-2024 at 07:24 PM. |
#30 |
![]() ![]() ![]() ![]() Drives: 2023 ZL1 Join Date: Dec 2022
Z OH 6, would that size fit the non 1LE also does this require a speedo change in HP Tuners...
Katech Track Day CAM 38%•BTR Dual Valve Springs-Johnson Lifters•Trend 3/8 Chromoly Pushrods• VVT Del•CNC Ported Heads•AFM Delete• C5-R Timing Chain•Katech Oil Pump•Katech 112mm•Maggie 2650 3.25” Upper & ATI SD w/10.32” +20%•10 Rib Belt•RFBG•FI Interchiller Stage 2•THPSI Port w/875cc Inj•Dual Drop In Fuel Pump•DSX Aux Pump•Stainless Works 2" w/Legend NPP Axle Back•GESI UHO 4.5" CATs•Brisk RR14S Plugs•BMR Motor Mounts•BMR Cradle Lockout/Bushings Kit•DSS Chromoly DS•RPM 8-Point Roll Cage•10lb FireSense+ w/4Fire SFI 17.1 Fire Sys•Weld Forged Vitesse Rear 17x10 Beadlocks-Front 18x6•Unlocked TCM
#31 |
Are you sure? I run 305/35/20s in the rear and there is only a (camel) hair's breadth of clearance on the driver side with the already relocated main body harness... a 315 is even taller by a third of an inch...
#32 |
#33 |
You may be right, when I originally replied, I was thinking about a 315/30/20, not a 35, but then I started thinking a few people have run a 315/35/20 but I could be wrong. It is quite a difference in tire height especially if the car is lowered.
#34 |
Yup, 315/30/20 is a sweet spot. Too bad many tire options aren't manufactured in that size, including the Nitto 555RII or the Michelin Pilot Super Sport.
#35 |
![]() Drives: 18 ZL1 - M6 Join Date: Mar 2019
Not trying to Hijack the thread, but does anyone know the max 20” tire size for the Z’s?
From what I’ve read so far, it sounds like a safe size for the rear is 305/30/20. But, what about the fronts, assuming no rubbing or mods? Thanks everyone |
#36 |
![]() ![]() ![]() Drives: 2019 zl1 6 speed Join Date: Jul 2017
I believe the ps4's can go up to a 315 on the rear of a zl1 and 295 on ss's, because they are smaller than most tires.
#37 | |
![]() Drives: Z06 Join Date: Oct 2021
#38 |
Tire compound is FAR more important for traction than tire width. Your 315 PS4S's are no match for a 305 555R2.
#39 |
#40 |
![]() Drives: 2018 Zl1 Camaro Join Date: Feb 2018
Im running 325/30/ZR20 PS Cup 2 with 5mm spacer and no issues.
Big Gulp|NW103|SW Headers|UHO CATS|XPipe|Borla Atak|MM CC|Kong Ported|NSX|ATI Damper|DSX 9.45 Lower|ZPE 2.5 Upper|DM Tensioner|FW Green Belt/BTR Gen V LT4 Cam w/32% lobe/BTR VVT Lockout/Pratt & Miller Chain/BTR Pushrods,Valve Springs, Retainers, Hydraulic Lifters & Guide Plate, Trunnion Roller|Katech Valley|KaTech Valve Covers|MSD Coils|DSX E Sensor & Aux Pump|ICT Water Pump|Katech Oil Pump|Cordes & Mishimoto Expansion Tanks|P3 Gauge|LC-2 Wideband Sensor|KaTech Wires|DynoJet Tuned
#41 | |
Also update on my new R555R2's - These babies really hook up nice on the street so far! Pretty impressed so far. I didn't make it out to Tune and Test Evening at Summit/National Trails on 6/28, I really need to get this interchiller installed and get the IATs down when the days are hot here, >85°+ a lot lately! Going to find a nice cool morning and do a Dragy 60mph to 130mph and get a time/distance!
#42 | |
Snackbar Tuning
Drives: 2023 SGM ZL1 Join Date: Oct 2016
GM Gen V Calibrator
