#29 | |
2020 Shadow Gray 2SS
Even in Track Mode the NPP will close at certain RPM and throttle settings, the only way to have them open 100% of the time is either tune it that way or pull the NPP fuse (which is what I did) and they will stay open 100% of the time...
After delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Pedals, SS Wheel Caps, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF-Full Front & Rockers, 35% Tint, CeramicPro coated, RST Stainless Brake Lines, Castrol SRF, MSD Plug Wires, Mamo V3 Ported TB Left: My "fun" ride (475 HP). Right: My "work" ride (52,000 HP): a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph. BOTH AWESOME to operate... |
#30 |
They are different and neither commands the valves open all the time. There are separate tables in the tune that control valve positioning as a function of rpm and torque, and the contents of this table are different in each mode. As 2SS Capt said above, there is a small range within the track mode table (low load highway cruising) that instructs the module (not sure if it's the ECM or the FSCM / CCM, but one of the two) to close the valves.
#31 |
![]() Drives: Camaro SS 1LE M6 Join Date: Feb 2024
Do the valves fully open when starting the car for a period of time?
#32 |
![]() Drives: Camaro Join Date: Jun 2023
#33 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro ZL1 Coupe Join Date: May 2016
Definitely in track mode they are open.
#34 |
![]() Drives: '23 RRT 2SS 1LE M6, '15 SIM 1LS M6 Join Date: Oct 2015
In my experience (2SS 1LE), even shutting down in "stealth" still results in next cold start with NPP valves open. = neighbors hating
What am I missing?
2015 SIM 1LS M6 - fun DD commute car 2023 RRT 2SS 1LE M6 w/PDR - FUN!! |
#35 | |
If fast catalyst warmup is enabled in the tune (it is by default), you will still have a little bark in the first half second or so, but then the exhaust will immediately quiet down. I personally haven't seen a Camaro with this changed or turned off, so I don't know if it's actually possible to have a fully quiet cold start.
#36 |
![]() Drives: 2SS 1LE Join Date: Jul 2023
Cold starts w the NPP exhaust are just the best.
2024 2SS 1LE | 6MT | Riverside Blue
1100 - Order submitted - 7/12/23 2000 - Order accepted - 8/22/23 Vehicle Built (per chevy chat bot) - 10/10/23 Window sticker available online - 11/4/23 Arrived at dealership - 11/10/23 |
#37 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '17 2SS convertible'20 Yukon Denali Join Date: Nov 2011
Sport mode always and fuse F51 out to keep the valves open.
Richard
2017 2SS SIM convertible, A8, NPP, MRC, 56R wheels, GM CAI, Diode Dynamics Side Markers, Mamo Throttle Body Delivered: 08/15/2016 #TeamBeckyD |
#38 |
Drives: Camaro SS Join Date: Aug 2023
