Old 01-11-2024, 07:12 PM   #29
MyNameIs
Drives: Camaro SS
Whats a money shift? Is this a stick?
MyNameIs is offline   Reply With Quote
Old 01-11-2024, 07:17 PM   #30
Hostile_1LE
Hostile_1LE's Avatar
Drives: 2020 Camaro SS 1LE | Satin Steel
Yes its an M6 car. In my case, it was where my friend went from 3rd to 2nd, instead of 4th. This happened at near the limiter so it likely saw 7500-8000 rpm.
HCI | GPI SS3 | E85 | xxx whp \ xxx tq
Hostile_1LE is offline   Reply With Quote
Old 01-11-2024, 08:35 PM   #31
speedyink1
speedyink1's Avatar
Drives: 2023 Camaro 1SS 1LE 6MT
I find the shape of the shifter lends itself to be handled with the "thumbs down approach". I find it kind of uncomfortable to "gorilla grip" it (I dunno, guess I'll call it that). Glad I got used to it that way, never thought of this happening (I've never moneyshifted so it's not on my mind).
MyNamels, to add to Hostile_1le's description, they call it the money shift because it when it happens it's gonna cost you money.
speedyink1 is offline   Reply With Quote
Old 01-11-2024, 08:59 PM   #32
SS_Don
SS_Don's Avatar
Drives: '22 Camaro 2SS
A money shift, for those lucky enough not to have encountered the problem, is when a driver attempts to go up a gear with a manual transmission, in this case from third to fourth, but instead goes down a gear. The term comes from the high expense involved in fixing the consequences of the botched shift.
'22 2SS | Wild Cherry Tintcoat | Design Package 3 | NPP | MRC | A10 | NAV | Ceramic Coating | Full Frontal PPF | New Hood and Side Stripes | Michelin PS AS 4 | Range AFM Disabler
Mishimoto Catch Can | Diode Dynamics side markers | Cold Air Inductions CAI | LLoyd Velourtex front/trunk mats with Camaro SS logo | Footwell Lighting | Umbra Sequential LED Taillights
ZL1addons Deluxe Rock Guards, Stealth Lift Pads, and Tow Hook | Escort MAXcam360c | Banks Data Pro and Pro gauges in ZZPerformance pillar pod | Paddle shifter extensions
SS_Don is offline   Reply With Quote
Old 01-12-2024, 05:35 AM   #33
Mid_Life_Crisis
Mid_Life_Crisis's Avatar
Drives: 2023 Chevy Camaro 2LT V6 6MT
It’s a shame the computer isn’t smart enough to lock out such a move. Basically hit a wall to prevent a mathematical too high RPM event.
2023 Camaro 2LT V6 6MT Vivid Orange Metallic
Mid_Life_Crisis is offline   Reply With Quote
Old 01-12-2024, 07:11 AM   #34
Cardiak
Drives: Boat
People just need to learn how to shift more precisely. It's already way too easy to drive these modern day manuals as it is.
Cardiak is offline   Reply With Quote
Old 01-12-2024, 07:19 AM   #35
That is one of the reasons the automatic transmission was developed. With a manual transmission, there is a mechanical coupling managed directly by the driver---which is the entire point of having such an old school system in the 2020s. If you insert any computer controlled element (past the engine) to decouple the driveline, you no longer have a manual transmission per se.
As it stands, the coupling is impossible for the computer to defeat immediately in a vehicle with an internal combustion engine, even though the ECM does everything it can to prevent the overrev (cut spark, cut fuel), because there is a mechanical delay and revs will overshoot for a short while.
If you ask me, this is inherent and should not be fixed. A significant portion of the manual experience is knowing that you are in control of the drivetrain, if you mess up, you can take out the engine. As we say it in Hungary, one can't stay a virgin and have children, too.
(Btw I drive an automatic Camaro today, but learned on and drove stick for a long time.)
Old 01-12-2024, 07:40 AM   #36
The Chief (tm)
The Chief (tm)'s Avatar
Drives: 2016 Camaro 2SS "Convertibobble"
On the face of it, one *could* say its sorta odd that the computer can force the 1-to-4 upshift, but cannot prevent the over-rev downshift.
But I know it's not apples-to-apples.
'16 2SS Garnet Red ~24K
"Mods": GM wind deflector, home-made rear seat delete & platform, not-quite garnet red key fob cover (+10rwhp)
'99 4Runner 367K
'94 ST1100 146K
The Chief (tm) is offline   Reply With Quote
Old 01-12-2024, 08:15 AM   #37
SS_Don
SS_Don's Avatar
It’s not a computer thing. It’s a mechanical thing. How can the computer stop you from mis-shifting? Once you mis-shift it is the rear wheels that is pushing the engine to over rev. Even with your foot off the gas pedal the car is making the engine over rev.
Old 01-12-2024, 09:53 AM   #38
Hostile_1LE
The Camaro has a lockout solenoid on 2nd. just like reverse. However it’s only ever used to go from 1 to 4.
Old 01-12-2024, 12:39 PM   #39
MyNameIs
Drives: Camaro SS
Ahh shucks I do that all the time and ever since I bought it new. over 67k miles now. Should be ok to do that as rev match controls it and they rev limiter protects over revving. But anything can happen.
Old 01-12-2024, 12:42 PM   #40
MyNameIs
Drives: Camaro SS
Was rev match on or off?
Old 01-12-2024, 12:58 PM   #41
Even that mild lockout is seen as a problem by many who prefer the manual. In addition, it would be much more complex to "extend" that to any downshift pattern that might result in an overrev.
Old 01-12-2024, 01:19 PM   #42
Hostile_1LE
Rev match was off, but it wouldn't have made a difference. At the speed the car was going, the tires carried then engine well above the limiter.
