Old 08-03-2023, 07:36 PM   #29
Stevezx900
Stevezx900's Avatar
Drives: Buick Grand National, BMW M5
Originally Posted by Stevezx900 View Post
I have the Bendpak HD9.
Great lift also track is adjustable for wider vehicles!
Just incase I ever buy a Lamborghini or something similar!
My ceilings are only 10.0 feet.
I have a Buick GN on top and the ZL1 on the bottom.
They fit perfectly in my garage. Anything else may be too tight.
Stevezx900 is offline   Reply With Quote
Old 08-03-2023, 07:43 PM   #30
CalgaryZL1
CalgaryZL1's Avatar
Drives: 2020 Chevy Camaro ZL1
I only have a 9 foot ceiling and I can just fit the Camaro and the 1997 Z3
Old 08-22-2023, 12:17 AM   #31
AustinZL1
Drives: 2018 ZL1 1LE
I would love to see your setup. I'm in a similar spot and would love to have a 2013 ZR1 under a 2018 ZLE. Got any pics?
AustinZL1 is offline   Reply With Quote
Old 08-22-2023, 07:44 AM   #32
Rapid_blue_zl1_22
See you at the Track!
Rapid_blue_zl1_22's Avatar
Drives: 2022 Rapid Blue SS 1LE
Overall 2 post IMO is a much more usable lift. Much easier to swap wheels, make suspension adjustments, as well as most other routine maintenance. You can still park another car under a 2 post as well. I currently have a low rise MaxJax lift, but I'm looking into getting a full size BendPak soon. If you only want it for storage and don't plan to work on any of your cars, the 4 post is definitely the better option.
2022 M6 Rapid Blue 1SS 1LE PDR (Current)
2022 M6 Rapid Blue ZL1 (SOLD)
Rapid_blue_zl1_22 is offline   Reply With Quote
Old 08-22-2023, 08:20 AM   #33
CW3SF
CW3SF's Avatar
Drives: 2019 Chevy Camaro ZL1 M6
Originally Posted by pauly1119 View Post
Also you might want to locate the garage door opener to a wall mount version. My ceilings are 13 feet.
This is probably the most important bit of information in this thread. More often than not the limiting factor isn’t the height of the ceiling. It’s the height of the garage door when it’s in the open position and the height of ceiling mounted opener. Just by design, adding the wall mount opener and raising the door rails will get you more lifting space.
CW3SF is offline   Reply With Quote
Old 08-22-2023, 03:27 PM   #34
gotswap
gotswap's Avatar
Drives: 2019 ZL1 Crush
Jack shaft door opener and Bendpak lift all the way
2019 Crush A10
E-Force 2650
670WHP 615WTQ
All besides the 2650 is bone stock down to the air filter.
gotswap is offline   Reply With Quote
Old 08-24-2023, 02:14 PM   #35
CalgaryZL1
CalgaryZL1's Avatar
Sorry no I don’t, my brother in-law is currently driving the Beamer, but with a 9’4” ceiling and with camaro on it there is a 51 inch clearance from the ground to underside of the lift platform
Old 12-22-2023, 09:33 AM   #36
Nice setup... and I really like the tire racks as well
I have 10' ceilings and I have no idea how this can be done at that height or even less. Has to be super close tolerances.
Old 12-23-2023, 04:36 PM   #37
cajunzl1
Drives: 2018 ZL1
not to hijack the thread, but I'm leaning towards a full rise scissor lift > Stratus is coming out with a 9000 lb scissor lift that will give a 6 foot working height
4 post are great but take up a lot of room, if your garage is small , IMO...
cajunzl1 is offline   Reply With Quote
Old 12-23-2023, 05:14 PM   #38
CTRifecta
CTRifecta's Avatar
Drives: 2SS 1LE
Good lord, look at those rear wheels/tires! how wide are those tires???
2024 2SS 1LE | 6MT | Riverside Blue
1100 - Order submitted - 7/12/23
2000 - Order accepted - 8/22/23
Vehicle Built (per chevy chat bot) - 10/10/23
Window sticker available online - 11/4/23
Arrived at dealership - 11/10/23
CTRifecta is offline   Reply With Quote
Old 12-25-2023, 09:16 AM   #39
laynlo15
Drives: 2022 Lt1 A10
Or you could consider a one post lift like my son in laws for his BMW M2. He had a 3 car garage on his last house. They build a new house but due to constraints on the lot size they went up instead of out. So he found these one post lifts and decided to buy one. They are the heaviest steel I've seen, it's pretty awesome.
Old 12-25-2023, 04:50 PM   #40
Og Neon
Lover of Speed
Drives: 2018 ZLE
Attachment 1143343
Attachment 1143344
This lift scares me. I am sure it is fine, but that single-sided lift arm is nuts!
Killer Whale Racing
2021 One Lap of America Track Videos
2019 One Lap of America Track Videos
2017 One Lap of America Track Videos
2022 Ram TRX
2018 Camaro ZL1 1LE
2020 Range Rover Sport SVR (Sold)
2014 Grand Cherokee SRT (Sold)
2014 Camaro Z/28 (Sold)
Og Neon is offline   Reply With Quote
Old 12-25-2023, 05:38 PM   #41
It's scary and amazing at the same time The mere thought of the torque trying to twist it out of the concrete base when the lift is at its top position with a Camaro on it fills me with both fear and awe That said, I'm sure this setup works just fine, but it must require some crazy base prep.
Old 12-25-2023, 09:54 PM   #42
Rapid_blue_zl1_22
Thanks! My ceiling height is 10' (Maybe 10.5' I can't remember) as well. The low rise lift is great, but I want a full rise. I am going to remove the center rail/chain track on my door and go to a side mount opener. This allows the roof of the car to go all the way to the ceiling, and have 5.5-6' under the car.
They are just stock ZL1 1LE wheels/tires. 305/325
