Old 05-28-2023, 03:34 AM   #29
MakCamaro
Makis
MakCamaro's Avatar
Drives: 2020 Red Hot ZL1 A10
Originally Posted by LeonardS View Post
I put the front Rokblokz on my ZLE, because the installation is completely reversible. I wanted no additional holes in the liner or fender. They leave a fairly good amount of tire showing. I wish they were about 3/4” wider. The good part is that they are hardly noticeable. I have not installed the rears, because I don’t see that area being as big a problem as the fronts. I asked Rokblokz about a ZLE specific set that would be slightly wider, but that probably won’t happen.
So, they are confirmed to fit the ZL1? I am asking because on their website they state that they are not confirmed for the ZL1, yet the fact that they are fitted with screws, without the need to drill additional holes and without using sticking tape makes them the ideal choice.
https://rokblokz.com/products/chevro...31480470306859
Old 05-28-2023, 06:34 AM   #30
LeonardS
Yes, the fronts fit perfectly.
94 Z28, Black, M6, 595 miles
69 Z28, Dusk Blue, M4
29 Ford Business Coupe
28 Ford Pickup
24 GMC Denali 2500HD CCSB 4x4
22 Jeep Grand Cherokee
13 Ford F150 Crew Cab 4x4
Old 05-28-2023, 10:56 AM   #31
NYTMARE23
NYTMARE23
NYTMARE23's Avatar
Drives: Black 2023 ZL1 A10
Originally Posted by #8ZL1Man View Post
That's what I plan as well.
In the past, I've masked of the outside edges, and then sprayed a quick one-coat of black truck bed liner on the inside (facing the tires) before I mounted them. It kept the painted or carbon fiber guards from getting chipped up. (But leave the tape kind of open, and spray on an angle, so you don't get a hard 'line.')
Oh nice!! Well, damn...too late for me since I already mounted mine but that's a VERY good idea you have there!!
2023 A10 ZL1 "NYTMARE"
NYTMARE23 is offline   Reply With Quote
Old 05-29-2023, 03:57 AM   #32
MakCamaro
Makis
MakCamaro's Avatar
Great, thanks for confirming that LeonardS. I think they are the best out there and at a great price. I had them on my Mustang and I was very satisfied.
Old 05-29-2023, 04:23 PM   #33
Cheese ZL1
Drives: 23 Camaro ZL1
Thank you for all the great suggestions!
Cheese ZL1 is offline   Reply With Quote
Old 06-09-2023, 05:56 AM   #34
MakCamaro
Makis
MakCamaro's Avatar
I ended up going with the Rokblokz ones, as I've used them in the past and I was very satisfied. The area in front of my rear wheels had quite a few rock chips, so I had the paint corrected and then I installed the splash guards. Very happy with the installation, no double sided tape used and no need to drill new holes, so the installation is 100% reversible if needed. Everything was included in the kit they sent me, along with instructions and their customer service is great. One minor suggestion: if you decide to go with the Rokblokz splash guards, be aware that there are 3 spacers per side for the installation of the rear ones. Two of them are 10mm and the 3rd one is 25mm in length. Ask them to replace the 25mm spacer that comes with their kit with a 20mm one, otherwise the rear splash guards will not sit flash with the fender. I ended up replacing the 3rd rear spacer with a 8.3mm x 18mm x 20mm spacer that I bought online. I already informed Rokblokz about that and I suppose they will update their kit for the Camaro. They even sent me several spacers for me to try for free, even though I am in the UK.
All in all I definitely recommend the Rokblokz spalsh guards. They are easy to fit, they require no alteration whatsoever on the car, they stay in place and they look great.
Old 06-10-2023, 04:22 PM   #35
Cheese ZL1
I chose the ACS rock guards, looks like they came on the car. In my opinion they are worth the money.
Thanks for all the suggestions/opinions
Old 06-10-2023, 05:09 PM   #36
NYTMARE23
NYTMARE23
NYTMARE23's Avatar
Good choice! I love mine and I agree, we'll worth the money!
