#29 | |
Shadow Gray '19 ZLE M6
Appreciate the info. So there's at least a couple of us that have experienced this. I wish it was the idler pulley -- at least then I'd know what caused this.
PPF | Paint Correction | ZL1 Addons Rock Guards | ZL1 Addons Lift Pads | ZL1 Addons Feather Lite Tow Hook | JWM Smoked Sidemarkers | Wildhammer Smoked Rear Reflectors | JWM License Plate LEDs | RotoFab CAI | ADM IC Reservoir v2 | BC Forged RZ05 | SPL Toe Arms | BW Brake Deflectors | CMS Roll Bar | Schroth Profi II ASM Harnesses . Sold: '99 Trans Am (bolt-ons & cam) | '00 WS6 (bolt-ons, heads, cam, 12 bolt) | '05 CTS-V (bolt-ons, short throw) | '10 SS/RS M6 (short throw, CAI, coilovers, LTs, catback, JRE tune) | '01 WS6 YouTube |
#30 | |
![]() Drives: 2020 Rally Green ZL1-1LE Join Date: May 2020
I was at Putnam Park last Saturday and experienced the exact same thing. I replaced the t-stat housing out of caution after seeing a guy break his t-stat housing 2 years ago from a belt. I bought the AMP t-stat and housing which came with a 160 deg t-stat. I then bought the identical style motorad t-stat from the Moto-Rad Store online in a 180 deg to avoid a low coolant temp fault. I had no problems with the first 2 sessions. Session 3 it went to 260 with engine power reduction and immediately came down by the time I got back to the pits. Missed the rest of that session while I checked for an air pocket and put a secondary clamp on as the factory didnt seem to clamp well enough. Went out for session 4 and it did it again on lap 2. Dropped back to normal by the time I got to the pits. Missed the rest of that session while I put the original back in. Went out for session 5 and no problems! It just so happened the guy I saw this happen to 2 years ago told me he had problems until he purchased a Genuine GM LS3 stat. Thats what it took for him to run the new housing without problems. |
#31 | |
It sounds like I'm on the right track with the LS3 t-stat though. Good info. Thanks for sharing! I don't know what t-stat the DMS housing comes with, but I'm not going to use it anyway since it's a 160. I'll be using the Lingenfelter 174.
#32 |
Question -- can the plastic thermostat housing be separated from the thermostat? I saved my broken OEM thermostat housing & thermostat. Wondering if I can put the OEM thermostat into the aftermarket plastic housing. Not that it really matters since I have the billet housing & LS3 thermostat coming, but just curious.
#33 |
![]() Drives: 2019 Camaro ZL1 1LE Join Date: Nov 2021
My tensioner exploded and took out the belt or the belt took it out
