10-14-2023, 05:28 PM | #29 |
2022 LT1 non-1LE J55
rotors are 12.6" Does have Red Brembo fronts (J6F) which Rockauto lists these as a replacement for SS as well???? https://www.rockauto.com/en/catalog/...b,caliper,1704 |
10-14-2023, 05:35 PM | #30 | |
I don't know how one can obtain the full list these days. GM customer service used to email the build sheet with all the options and their descriptions in email, but they cut that service out as well...
10-14-2023, 06:37 PM | #31 | |
Long hauler
I believe J6F simply means red painted calipers from searching a few links and the forums I wouldn’t use J6F but I can’t 100% give you a straight answer unfortunately. I’d just bank on using the J55 solely and nothing else to search for pads if it was me
2016 1LT v6 - Totaled Happiness: Infinite |
10-15-2023, 09:00 AM | #32 | |
10-15-2023, 03:36 PM | #33 |
Long hauler
Yeah it should just be the color RPO. To my knowledge the only differing RPO for size calipers/rotors are the ones listed in my chart
11-19-2023, 07:27 AM | #34 |
Drives: 98 Camaro Join Date: Apr 2022
Bumbleboy92. Would it be safe to say that the lt1 with 12.6” rotor and the c8 corvette base with 12.6 rotor are interchangeable? If so I’m guessing the 13.6” that is on the newer lt1’s without copper pads would be interchangeable with c8 z51 front rotors
01-26-2024, 11:19 AM | #35 |
Long hauler
I believe there's a very slight difference in rotors but no clue on my behalf until someone tries really
01-26-2024, 11:26 AM | #36 |
Long hauler
Updated
Added options for LT / LT1 cars with 6-Piston front
Notes about 5LQ and PCU RPO codes Rearranged notes/comments
2016 1LT v6 - Totaled Happiness: Infinite Last edited by Bumbleboy92; 01-26-2024 at 11:40 AM. |
01-26-2024, 05:39 PM | #37 |
Drives: Chevy Camaro Join Date: Aug 2023
As far as I am aware, all LT1 Trims (2020-2024) use the J55 brakes, including California Models. My 23 has the J55 front brakes and it came from California.
2023 Black LT1 A10
2024 VOM 2SS 1LE Manual |
01-26-2024, 07:22 PM | #38 |
Are any of the 6 piston calipers direct bolt in for the LT1 Cars that only came w 4 piston calipers?
01-27-2024, 10:25 AM | #39 | |
Long hauler
PCU is the additional option for the SS that adds 6 Piston front/larger 4 Piston rear. So essentially, (click each link for an example) LT / LT1 regular cars will have J55 LT / LT1 cars with 6 Piston front upgrade will have both J55 and 5LQ SS cars with the “4 Corner Brake Upgrade” will have J6M, PCU, and 5LQ But the LT items only applies to 2020-2022 since they stopped offering them past 2022. PCU (4 Corner Brake Upgrade) for the SS was offered all the way to 2024. You’d need to buy new sized rotors, along with appropriate brake lines for any 6 Piston upgrade. But they will fit with the right rotor and brake line. Technically every single one of these RPO’s are interchangeable except the 1 Piston rear calipers as the parking brake is integrated on those
01-27-2024, 02:43 PM | #40 |
Drives: 2SS 1LE Join Date: Jul 2023
This is very helpful. It would be great if we could add the OEM brake pad part #s for each option too.
2024 2SS 1LE | 6MT | Riverside Blue
1100 - Order submitted - 7/12/23 2000 - Order accepted - 8/22/23 Vehicle Built (per chevy chat bot) - 10/10/23 Window sticker available online - 11/4/23 Arrived at dealership - 11/10/23 |
01-27-2024, 05:43 PM | #41 | |
Long hauler
According to this thread, 5LQ was seen in the 2016-2018 RPO codes so it may have been an option from the beginning
01-27-2024, 05:47 PM | #42 |
I was just reading about it, found out that 22 was the last year, and deleted my question haha. Definitely not a common thing, especially for $3,300.
2023 Black LT1 A10
Tags |
brake, brembo, rotor |
