Old 10-23-2023, 08:17 PM   #29
DaveC113
DaveC113's Avatar
Drives: 2018 Camaro 1SS 1LE
Originally Posted by GunMetalGrey View Post
Thanks for the info, I assume there’s a reasonably wide range of hide adjustment. I’m sure vorshlag will give me exact details. I’m not sure if they sell The resistors your mentioning or not, I’ve asked them as well.
You’re making me think of getting three-way adjustable myself, although I’m concerned there’s more for me to screw up haha I do like the idea of being able to adapt better to more variety of different circumstances on track and the street, since it seems these would also be more comfortable as well.
However, I’ve heard the remote reservoirs can be a PIA, and there are greater risks involved with the lines...
Can anyone chime in to the ride quality of the system for the street when adjusting them to a more comfortable setting compared to the DSSV’s on the ZLE? I don’t want to end up buying these and hitting them when I drive them on the highway., I don’t do city street driving, so at least the roads will be smooth and in good shape
These won't really be adjustable to be more confutable. Magride uses very soft springs and a lot of damping, it's a great system but if the main goal is performance the spring rates are too soft. For my SLE, fronts are something like 330 lbs (I could be off, it's been a while). With MCS you'd use more spring and less compression, 700-800 lb springs up front, so you won't be able to make adjustments to make the ride softer, it'll just be bouncier.
RR2 remote res ramps up damping forces 2x as fast as the TT2 non-remote, and has a lot more rebound damping This will make the ride a bit harsher for sure, but more controlled. TT2 will be smoother on the road. Going to coilovers will be a big compromise in ride quality vs magride, the contrast could be pretty jarring.
DaveC113 is online now   Reply With Quote
Old 10-23-2023, 09:18 PM   #30
Protocol
Drives: 2018 Camaro ZL1 1LE
Last, but not least I don’t know anybody on this forum yet who has experience with the DSC tractive system, however, based on what I’ve heard so far and as stated above, my understanding based off Robert Weathers is also that it needs to be fully custom calibrated to be of maximum value, and once again, it seems almost nobody really knows how to do that effectively, not to mention the time involved to test and tune over and over again. Which is too bad because it seems that there option has the potential of the best of both worlds., considering it sounds like it can be a soft Street ride, perhaps, unlike MCS and Detroit speed coil overs?
I have the DSC tractive system on my ZL1 1LE. In fact, it’s actually Robert Weathers’ former car.
I’m just starting to dive into learning more about the Tractive coilovers. They seem to be quite impressive, albeit complicated. Having had a stock ZLE previous to this car, I do have a direct comparison between these and the stock DSSV’s. I am sure that Robert has significant time in setting up the system on my car, and subjectively, the ride quality versus handling/performance is an impressively nice balance. The ride quality (not some thing I care too much about on this car) is better than the stock DSSV’s and the handling on the street feels almost identical to the DSSV’s. I haven’t had any track time with it yet.
The adjustability of the entire system is fantastic. I’ve talked to DSC on the phone about some initial adjustments and plan to reach out to them for further learning in the near future.
Protocol is offline   Reply With Quote
Old 10-24-2023, 12:05 AM   #31
GunMetalGrey
GunMetalGrey's Avatar
Drives: 2018 ZL1 (SOLD) 992 GT3 (current)
That’s funny, he just messaged me about his former car and said he’d put me in contact with you to see if you’d sell it because you weren’t taking it to the track haha
He’d be glad to know you were taking it to the track now!
Yeah, sounds like that would be the ideal set up in terms of comfort and track performance, if you want to sell the suspension, let me know!
2018 ZL1; Mag 2650 and 2 inch LT Headers , every SPL suspension upgrade, MCS 2 way coilovers, sway bars, square SC3R 325's all the way around, and multiple brake cooling upgrades
GunMetalGrey is offline   Reply With Quote
Old 10-24-2023, 12:13 AM   #32
GunMetalGrey
Thanks for setting me straight with that information regarding the differences between the TT2 and 3RR, my assumptions were obviously wrong.
Yeah, I’m a little worried about the ride quality issue, I don’t want to hate driving the car on the highway after making this change, however, I’d like to believe that the highway is smooth enough that it won’t be an issue since I never drive in the city.
MRC springs are actually even lower than that, 175 in the front…
My YYZ progressive rate springs start at 175 and go to 400 in the front. The rears start at about 450 and go to about 750
Even the DSSV’s I believe are 450 in the front and 1200 rear
Either way yes, that’s a big jump up for me to 600/600 for the GT springs, 700/800 for GTS or 800/1100 for the GTR springs… and I am surprised that they’d have even higher spring rates than the DSSV in the front at least
Do you know if they tailor the shocks valving to the springs that are chosen? Or are all TT2’s the same?
Lastly, in your own experience, does adjusting the settings down to a Street levels actually make them more comfortable to drive on the street in any significant manner?
Old 10-24-2023, 06:07 PM   #33
Chippy
BanHamWatch
Chippy's Avatar
Drives: 21 ZL1 1LE
2021 ZL1 1LE
Auto
Chippy is offline   Reply With Quote
Old 10-25-2023, 11:43 AM   #34
GunMetalGrey
MCS TT2 with GTS rate and progressive rate rear springs (tender spring) have been ordered!
Thank you everyone for your help! It was and is appreciate!
Old 01-04-2024, 05:11 PM   #35
carguy55
carguy55's Avatar
Drives: 2018 1SS 1LE
Interested to find out what spring rates you guys are using with the MCS coil overs.
I'm plan on going with RR2 = the remote res 2-ways.
Mods: MSD, Headers, 95mm TB, high flow cats, full 3" exhaust, SPL, MCS 2-way remotes, sway bars, rear diff lock outs, Sparco racing seats, 6 point harness, CMS roll bar, Nine lives wing, 6" splitter, ACS canards.
www.youtube.com/@Racer_Mike87
Old 01-04-2024, 05:36 PM   #36
DaveC113
DaveC113's Avatar
I got RR2s with 750/850 lb springs, coilover rears.
Mine are still in the boxes so can't give feedback yet.
Old 01-06-2024, 08:43 PM   #37
Og Neon
Lover of Speed
Drives: 2018 ZLE
I went with 800 fronts and 1200 rears. I also kept my rears divorced like the factory setup.
I love the swap over to MCS. I notice the biggest difference in how fast the car adapts especially when using the curbs. The car no longer gets unsettled using them which made a huge difference at Road Atlanta!
Killer Whale Racing
2021 One Lap of America Track Videos
2019 One Lap of America Track Videos
2017 One Lap of America Track Videos
2022 Ram TRX
2018 Camaro ZL1 1LE
2020 Range Rover Sport SVR (Sold)
2014 Grand Cherokee SRT (Sold)
2014 Camaro Z/28 (Sold)
Og Neon is offline   Reply With Quote
Old 07-05-2025, 06:27 PM   #38
gmansyz
Drives: 2022 1SS 1LE Camaro
Coilover Springs
I just wanted to say that it is now possible to add coil over springs to the mag ride struts.
I am thinking 600 lb/in in the front. Perhaps a better, simpler first step alternative to the coilovers and other solution?
Especially for the dreaded rollover with the stock 175 lb/in springs and excessive compression damping of the stock setup to try and compensate for the limp noodle springs of the stock units.
G
gmansyz is offline   Reply With Quote
Old 07-05-2025, 07:42 PM   #39
Tay
Drives: 1985 Oldsmobuick
Originally Posted by gmansyz View Post
I just wanted.to say that it is now possible to add coil over springs to the mag ride struts.
G
Link to the kit?
Tay is offline   Reply With Quote
Old 07-05-2025, 07:44 PM   #40
DaveC113
DaveC113's Avatar
G
Good idea, I tried to have custom springs made but an adapter to run common coils is even better.
You will 100% need the DSC Sport magride shock controller though. It could work out really well but the DSC is very complicated. If you tell DSC the spring rates you're running they will probably give you a base map for them if you buy the controller from them. However, I feel like the OEM programming was actually better in some key areas, like low speed damping, while DSC controlled the chassis better in some situations but worse in others.
So idk.. it is a good idea but at the end of the day I'd say save the cash up and buy a set of decent coilovers. My MCS RR2s are amazing, they result in a significantly faster and better handling car, having one rebound and comp knob per shock is enough for me, lol.
Old 11-20-2025, 04:00 PM   #41
gmansyz
Originally Posted by Tay View Post
Link to the kit?
No link yet. Seems I will be embarking on this adventure myself.
Old 11-25-2025, 12:31 PM   #42
gmansyz
I don't want to hijack this thread so will start a separate one.
Tnx
G
