#29 | |
#30 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2020 Camaro 2SS A10 Join Date: Jun 2018
And it turns out talking with JP he knows someone 5 minutes away who does FBO Tuning. Going to see if I can sweet talk him into installing the intake and TB along with the tuning. Even if I have to throw in a kegger.
#31 |
BLUPRINT_1LE
Drives: 2022 Rapid Blue SS 1LE Join Date: May 2017
What’s up Fluke, I think we talked on YT a lot of times. Look at the last few videos people posted, installing the intake manifold and throttle body is easy: it’s really 12-14 bolts total. 10 for the intake manifold and 4 for the throttle body. All of them between 10mm I believe. I can’t remember but it’s extremely easy. Order the manifold and throttle body for GPI and it comes with everything you need and bolt on ready as you walk thru the drop downs . It takes 1 hour literally, if you’re considering Katech I recommend doing the big jobs vs the FBO jobs, they can do it but you get more bang for your Buck with the higher stage packages because you get so much more IMHO. With that being said I did have the parts(LT2 intake, e85 sensor, ported TB and rotofab) installed before they started my build but I know my way around the car a little bit but going in it was working and I didn’t have any CEL lights. Was my car running to its fullest potential, probably not because I added it all with stock tune but once they’re done with it, it will be right. I don’t second guess them one bit. But I get your point on cost but there is multiple shops around or you can remote tune from a bunch of reputable shops as well. Vector Motorsports and CT performance is close to your region I believe. However like Katech_Mike said they don’t normally do customer supplied parts which they have a right to decline. Best of luck with your build too!
2022 Camaro SS 1LE | PDR | Rapid Blue | Manual | Katech Built SS 1LE | Katech Build Sheet
IG: BLUPRINT_1LE YT: BLUPRINT_1LE ---------------------------------------------------------------- Last edited by Blackmonba6Gen; 03-01-2023 at 03:01 PM. |
#32 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: like an old lady Join Date: Jun 2012
idk how gpi does their LT2 adaptation. also need the map extension harness. i did my own with parts from ace hardware, except the harness which i bought from mid michigan motorsports. took me about 30 minutes to modify the manifold and another 30 minutes to swap it. i had a catch can at the time so the vacuum port pointing up wasn't a big deal. it is a noticeable difference and will require a tune to capitalize on. i wouldn't look for a lot, 1.5-2 mph at the most. you're in it right? figuring out how to record & flash tunes should be ez pz. buy the stuff and let gpi remote tune the car. honestly i think it would pick up 2 mph just from them retuning it, as is.
#33 | |
Ya it is what it is. I understand why they don't want to do it, but going to them for similar output levels just seems more than I may need / should spend. I wish I had more disposable income, but I just don't.
#34 | |
![]() Drives: 21 Lt1 Join Date: Dec 2016
#35 | |
Wish him luck, but he's to good for us on woodward now. Error: 404 BLUEPRINT_1LE does not exist in Michigan
