#29 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2024 CT5-V Blackwing Join Date: Sep 2020
#30 |
The engines are already "pre broke in" at GM before you purchase the vehicle. All the end user is doing is finishing the back end of the break-in process. Now when you put a new never ran engine in a vehicle there is procedure that should be followed. It involves using a break-in oil, starting engine and holding rpm at 2500-3000rpm until up to temp. Then load cycle the engine. Dyno makes this easier but can be done on the street by taking the engine up to 4k rpm or so then decelerate on the engine in the same gear... repeating several times. Use different gears for different loads. Change oil at 500 miles and send it.
#31 |
I broke in the engine the same way King is suggesting above, changed the oil at 500 and then both oil and diff fluid at 1500, and never had any issues with power or oil consumption. I have a catch can as well, it doesn't collect much, which makes sense (but even then I'm glad that gunk doesn't go back in the engine, whether or not it would burn off completely).
#32 | |
![]() ![]() ![]() Drives: 2019 ZL1 Riverside Join Date: Apr 2020
"Just follow what the engineers say" is the same blind argument BMW E92 owners STILL use to justify 10W-60 motor oil. Engineers are humans. Actual science and data prevails How much blowby are you getting every 3-5k miles? Have you run a compression check? |
#33 | |
Engineers are people but LOTS of testing went into the testing of these vehicles so I agree that data science and data prevails. If a mistake was discovered after the vehicle was released, there would be updated guidance on how to break-in the vehicle but that's not the case here with the ZL1 platform and as history has shown, these cars are quite reliable following the recommended break-in procedures. These aren't BMW's which aren't known for reliability. |
#34 | |
Drives: Chevy Camaro ZL1 Join Date: Feb 2023
Remember, the great debate ender here is that only a small subset of owners of these cars are enthusiast like we are, obsessing over oils and spark plug gaps and so on. The majority of these cars are in the hands of joe and jane and they dont care what oil jiffy lube puts in and are lucky if they even get an oil change in the 3-5k range let alone earlier or after break ins. And you dont hear about mass failures of vehicles all over the country due to joe and jane doe not using catch cans on their daily driven camaros. We as enthusiasts get ourselves all isolated like we are the only ones that own these cars and seem to know better than the engineers that designed and tested them, or the hundreds of thousands of non enthusiast owners that drive them 10x or 20x more miles then we ever will, without a problem. |
#35 | |
![]() ![]() ![]() Drives: 2018 ZL-1 Join Date: Jan 2018
Some enthusiasts on this forum take great care of their ZL-1s, cherish them, and want the best performance and longevity from their cars. Therefore, some install catch cans. The cans actually catch oil vapors and other goo that would have been introduced into the supercharger. Fact. That goo deposits on the back of the intake valves and inside the supercharger. Fact. As far as the GM engineers go, I don't trust them very much. They are responsible for signing off on the the oil pumps in this engine. Big fail. Also, engineers never get everything they want in a car, because the bean counters tell them to cut corners. If YOU don't want a catch can, not one person here has a problem with that. It's your car. Do as you wish. Why do you care if others here have catch cans on their cars? Do you critique other's wheel choices, tire choices, modifications, etc? Also, don't conflate engine break-in with catch cans. Catch cans collect engine blow-by. Break-in does the obvious. However, it is common knowledge that a long and gentle break-in will eventually lead to oil consumption, but that usually happens long down the road. A "firm" break-in will lead to an oil tight engine for life. Don't want to break in your engine like some of us do? Then don't. Follow the advice of GM. But let's leave the catch can shaming off the forum. |
#36 | |
#37 | |
Drives: 2020 Camaro ZL1 Join Date: Oct 2020
#38 |
#39 |
#40 |
#41 |
#42 | ||
