#29 | |
![]() ![]() Drives: 2017 Camaro SS 50th Anniversary Join Date: Apr 2021
#30 |
Awesome! I was looking at the Fragola 6000 series as well as the Vibrant stuff. Good feedback. Helps to know what others like and/or are using.
#31 | |
BAMF SS
Just my .02 though.
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock 800 SAE rwhp. 9.4 @ 145 mph. |
#32 |
I used Fragola PTFE line and Racetronix PTFE AN fittings and it all worked fine together.
#33 |
BAMF SS
Part out
#34 |
#35 |
While I'm waiting for the PI kit to ship... let's talk boost and pulleys.
In order to raise average boost, as a side effect, I'll be raising peak boost too. What's a safe average and peak boost for SBE? If I wanted to target 10 psi average, I'm thinking that might be around 12 psi peak. I'm also thinking I'll be in the neighborhood of a 3.7" pulley, and can play with shift points to tweak to something safe.
#36 |
I think 10 to 12 boost is pretty safe especially since you'll be running E85. I don't know anything about the pulley sizes for PC.
#37 | |
BAMF SS
after that, you can play around with the procharger rpm calculator found here: https://www.procharger.com/supercharger-calculators/ additional note: the general rule of thumb is that every 0.1 change in pulley size on the upper will equal ~ 1 psi. that is again a rule of thumb. I ran a 3.9 upper and 8.25 lower and had ~10 psi in a fairly free flowing FBO engine. Results are in signature.
#38 | |
![]() Drives: 21 Lt1 Join Date: Dec 2016
8.25 pulley and 3.7 upper on forged, cam, ported heads was making 13.5 psi in summer and 15 psi in sub 60* temps at 6800 rpm, if I take it to 7-7200 I gain almost 1.25 psi. |
#39 |
Great info! Looks like I have the 7.65 lower, so seems to me like the 3.7" is the right choice for what I want.
DSX Aux Low Side | LT4 high side | Flex Fuel TooHighPsi Port Injection (installed & tuning) CircleD 3K Stall | QA1 CF Driveshaft Forgestar F14 Drag 17x10 NT555R2 305/45/17 Rear Forgestar F14 18x8 NT555G2 235/50/18 Front 10.84@131 w/4.13" pulley ??.??@??? w/3.7" pulley (installed & tuning) Last edited by cjperformance; 02-28-2023 at 05:09 PM. |
#40 | |
BAMF SS
I would honestly start with putting an ATI underwrite pulley on, and a 8.25 lower. Increasing pulley size on either upper or lower will increase your contact patch, and have less of a chance for belt slip. Naturally going down in size increases your risk of belt slip. Typically belts start to slip in the 3.5- 3.7 range. Also you get to have better dampening and the underwrite pulley frees up some cheap horsepower as well.
#41 |
4.13 now.
#42 | |
You can get a btr Trinity with pi holes cnc ported for less then the plates i believe, at the end of the day it’s your build thou. I was merely curious is all. Thx JP |
