Old 02-21-2023, 05:12 PM   #29
DangerZL1
Drives: 2023 Black ZL1 Auto
I thought the switch to 0W 40 was to reduce carbon build up on the valves.
Old 02-21-2023, 05:24 PM   #30
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
In general, lowering the upper values is a fuel saving measure. Recommendations went from 40 to 30 and even as low as 20 for some cars. Like all engineering decisions, there are trade-offs. In this case, the trade-off was lubricity during high output driving.
As fo the lower value, there is absolutely no downside to going from 5 to 0, since low viscosity at start-up gets the oil flowing and into gaps more effectively.
But in the end, the most important consideration, for me, is that, given all the variables, which include fits, finishes, and bearing surface materials, the GM engineers know what's best, and not you and me.
Old 02-21-2023, 05:41 PM   #31
These threads always end the exact same way: predictably, someone with experience will try to contribute information that is not a carbon copy of the owner's manual, at which point someone else will appeal to the authority of GM engineering... end of discussion.
In general, corporate engineers have access to way more information than us outsiders, but (apart from a few exceptions) they aren't allowed to make decisions that are best for longevity or performance or user experience, because cost cutting, regulatory pressures, sales targets, quarterly results, shareholder benefit maximization etc. often override design and engineering recommendations.
Thus it's quite plausible that someone can provide germane, sound advice even without access to all the information that GM engineering does. Also, being in the know about engine design details doesn't automatically mean there cannot be others with more expertise outside the company.
BTW I have been using Amsoil Signature 10W-30 oil since the latest round of engine mods as recommended by Ted Jannetty, and never had an issue.
Old 02-21-2023, 05:46 PM   #32
ZX-10R
ZX-10R's Avatar
Drives: 2019 ZL1 Riverside
Valve coking is a result of oil blowby, oil viscosity has a marginal effect. Running thicker oil for that reason (alone) is another band aid (just like running thicker oil in the 1LE is a band aid for oil starvation for wet sump applications).
Yes - Amsoil Signature 10W-30 is probably the best stuff out there, with countless UOAs and standardized test results to back it up, not just internet opinions
ZX-10R is offline   Reply With Quote
Old 02-21-2023, 05:49 PM   #33
ZX-10R
ZX-10R's Avatar
GM engineers are constrained by fleet fuel economy goals and cost cutting compromises. They clearly state the *only* purpose of the 1LE high viscosity oil spec is possible oil starvation in a wet sump application. It's a band aid
Old 02-21-2023, 05:52 PM   #34
DangerZL1
I too trust what the GM recommended oil is and see no reason to change in a stock car driven on the street.
Old 02-21-2023, 07:17 PM   #35
Vigilante375
Drives: 2018 Camaro ZL1
All I know is that the Mobil 1 0w40 hasn't shown me any negative effects on my stock ZL1. Plenty of track days in hot weather and plenty of spirited time on the streets.
Neither did the lady who had the 220k mile ZL1 before she sold it to get something more economical. Though she was using mobil 1 5w30.
Old 02-22-2023, 07:09 AM   #36
Drnick
Drives: 22’ ZL1
Well, that was very informative post!, thanks for all the
Info, this will obviously go down in the annuals of “Another
Oil post”, for future distribution amongst forum members
Next time I’ll just do a poll, instead of asking a question
Drnick is offline   Reply With Quote
Old 02-22-2023, 09:15 AM   #37
ZX-10R
ZX-10R's Avatar
Is this "lady" a member? That has to be near a record...wonder how much oil it used every 5k
Of course she used 5W-30, she didn't buy the rhetoric. It's only been proven for 20 years, the only thing that has changed is this insane fixation on fuel economy ("0" weight oils, which is a lie) or people that naively think you still need to run a 40 weight in a modern engine. Both are equally clueless
Old 02-22-2023, 09:24 AM   #38
pauly1119
pauly1119's Avatar
Drives: 2018 ZLE
You knew what was going to happen if you asked the question. I think your picture says it all but seriously I don’t know why we try to outsmart the engineers that design our cars but if you try something other then the specs ask for you should send a sample in to Blackstone afterwards and see what the results show. At least then you can have something real and not just google search answers.
pauly1119 is offline   Reply With Quote
Old 02-22-2023, 09:59 AM   #39
ZLRob
Super Stock
ZLRob's Avatar
Drives: Chevrolet Camaro ZL1
Originally Posted by ZX-10R View Post
Here's the truth: "zero" weight oil is a marketing gimmick, and manufacturers recommending ultra thin oils is a strictly concession to the hyper fuel economy agenda, rather than longevity of your engine
On the flip side, 40+ weight is too heavy for any street engine (and questionable benefit for a race engine). GM's call for 40+ in the Camaro is strictly to mitigate oil starvation during high G loads when cornering with a wet sump. It again has nothing to do with engine longevity and those thick oils are have terrible cold flow properties. Who knows, may be a contributor to oil pump failures
Run 5W-30 or 10W-30 in any engine and you will be fine. Turn off the noise. My brother worked for GM Advanced Vehicle Engineering over 30 years
Dexos is bs, don't worry about it. Amsoil Signature exceeds any standard out there
Don't give a good goddamn what other people in these posts are saying. It's very evident to me who knows what's what and you boys are in the know about things outside of what is stated in the manual. Anyone who tells me to consult with the manual and that the engineers know what's best is an automatic red flag to me.
Do the engineers know what's best? Yeah, they do. Does that mean that they are constrained by pressures outside of their control making them recommend oils that you shouldn't run in your vehicle in order to appeal to this hyper fuel economy crap? Well, yeah, they do. It's always do your homework, and question the question when it comes to this stuff because the engineers don't always have the longevity of your engine in mind when making their documented recommendations.
I read a while ago that oil flow is always better than pressure. That singular statement really spoke to me. 5-30 Amsoil is what I'm sticking to.
758 HP/ 804 TQ
Old 02-22-2023, 12:30 PM   #40
Vigilante375
I don't think so. But her name has come up a few times. She was on a ZL1 Facebook group.
https://ibb.co/ZGt24h8
Of course she ran what GM said and it was the inferior Mobil 1 as well compared to the "vastly" superior Amsoil.
Everyone puts what they want into their vehicles but it just becomes a penis size check when people start to say "Well according to the scientific data from 50 years of (enter oil manufacturer name) that they are better than any other brand".
I have no issues with 0w40 in my car and neither has anyone else. Those LT4s that have a bad oil pump are going to fail no matter what brand of oil is in them nor what viscosity or weight or additives.
Old 02-22-2023, 02:36 PM   #41
ZX-10R
ZX-10R's Avatar
Impressive
I don't think anyone said "vastly" superior - almost all modern synthetics are pretty good - but the data (UOAs and standardized testing) has consistently shown Amsoil is excellent. Probably more important is keeping up with 5000 miles oil change intervals on the street, or less if racing
Agree
Old 02-22-2023, 02:52 PM   #42
CW3SF
CW3SF's Avatar
Drives: 2019 Chevy Camaro ZL1 M6
I’d say the young ladies data also suggests that Mobil 1 is pretty good as well.
CW3SF is offline   Reply With Quote
