Old 02-22-2023, 09:15 AM   #29
WhiteMale
Drives: 23 ZL1 A10 Rapid Blue
I got 2500 out of my factory R3 tires. I didn't reduce camber much, but last summer I otherwise replaced all of GM's negative camber, castor, toe, steer ahead, and thrust angle with neutral/positive settings. The car is so much easier to drive around town and I haven't seen any wear on these Toyos.
YOu did a lot in your signature block to a ZLE and then neutered it with Toyo tires and this alignment, makes little sense.
Too, caster is not adjustable, Camber does not wear tires, toe wears tires. What you did makes no sense.
Old 02-22-2023, 10:22 AM   #30
JSH
JSH's Avatar
Drives: '20 ZLE
It makes perfect sense for a straight-ahead car. Improper camber can make the tire wear on one edge, which it did. I left some camber in it but zero camber will result in the most uniform tire wear. This Toyo makes a really good dry road and strip tire. I'll buy the Nitto 555Rii in 345 if and when it ever becomes available again.
2020 ZL1LE A10.
100 octane: 1045hp/1055tq.
Old 02-22-2023, 10:26 AM   #31
Rayvan
Rayvan
Drives: 2018 1SS1LE, Silver Ice Metallic
Run them until they're cording. Anyone who "thinks" than their F1 tires are "shot" at only a few thousand miles can send them to me. I'll double that easy, and I track my car.
My rears corded at 14,000 miles. My fronts are still "trackable" at 16,000.
Seriously, I'll pay the shipping.
Rayvan is offline   Reply With Quote
Old 02-22-2023, 12:18 PM   #32
Vigilante375
Drives: 2018 Camaro ZL1
Camber does wear tires more on which offset you have then on which will lead to uneven wear.
One side of the tire will look brand new while the other will look like it's been on there for 100,000 miles.
Old 02-22-2023, 05:34 PM   #33
Raisin Man
Drives: Chevrolet Camaro
9700 miles and I still have 2mm of slick rubber left (dimples).
Also a fan of the OE Goodyear's. Expecting no more than 8-12K miles on a set of these tires. Longevity probably about the same vs. other manufacturers for a high performance summer tire with proper alignment. Only have about 3K miles on my 2022 ZL1, but the Goodyear's stick like a mofo. Michelin OK of course, and I have Pilot Sports on other cars, but I'll buy the Goodyears again for ZL1.
Raisin Man is offline   Reply With Quote
Old 02-22-2023, 05:58 PM   #34
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
I will probably get another set of Goodyear tires for my ZL1 when comes time to replace mine. That’s what the ZL1 was designed for but everyone is different.
Old 02-22-2023, 06:16 PM   #35
JSH
JSH's Avatar
Drives: '20 ZLE
I think I've still got my 3R's. If so, do you want them?
2020 ZL1LE A10.
