Old 01-29-2023, 10:37 AM   #29
Christian1LE
Drives: 2004 BMW 330CI, 2022 1SS 1LE
411 HP stock? That's high isn't it?
Christian1LE is offline   Reply With Quote
Old 01-29-2023, 11:10 AM   #30
Katech_Zach
Katech_Zach's Avatar
Drives: 14 Camaro SS 1LE
We typically see 11-12% drivetrain loss on a manual Camaro, it is about right where we would expect it to be. Maybe a smidge high, but that error is negligible from air quality, dyno cal, etc. We see the baselines range from 395 to 415 on these
Katech_Zach is offline   Reply With Quote
Old 01-29-2023, 01:58 PM   #31
SDF62
Awesome build! That Anderson Carbon hood is sweet! Do you have heat shielding underneath? I assume you will be putting front hood latches on it? I will be interested in seeing how that goes...I am considering the same hood.
SDF62 is offline   Reply With Quote
Old 01-30-2023, 08:56 PM   #32
SCCAForums
SCCAForums's Avatar
Drives: Chevrolet Camaro, Ford Mustang
Thanks, will be posting pics here shortly! As for underneath, we're trying to use a high temp/heat resistant clear coat and see how it holds up. And yeah, ordered front hood latches as well, although have heard/seen others with good success on track using just the factory hood latch and struts.
Best regards,
Dave
2022 SS 1LE - Vivid Orange - SCCA CAM-C & Optima Ultimate Street Car GT
Katech, MSD, QA1, Hurst, Anderson Composites, ProParts USA Custom Suspension, Auto Addict USA, Forgeline Wheels, G-Loc Brakes, Nine Lives Racing, MTX Audio, Penske Rapid Repair, RacingBrake
SCCAForums is offline   Reply With Quote
Old 01-31-2023, 07:16 AM   #33
6spdhyperblue
Drives: 2SS 1LE
Why did you swap to those intake valves?
Old 01-31-2023, 03:46 PM   #34
That1guy_tim
That1guy_tim's Avatar
Drives: Camaro 1ss
Put a high ram on it and let it breath!
Love the build, you have my dream exhaust setup.
Are you going to be running a diffuser? Never mind I reread the the first post
That1guy_tim is offline   Reply With Quote
Old 01-31-2023, 03:51 PM   #35
That1guy_tim
Drives: Camaro 1ss
Lighter valves help keep the valve train in check at high RPM.
Old 02-01-2023, 12:26 PM   #36
6spdhyperblue
Drives: 2SS 1LE
Is that or is it risk from the valve breaking off the stem?
Old 02-01-2023, 12:43 PM   #37
Katech_Zach
We haven't had any issues with factory LT1 valves breaking with a stable valvetrain. The factory intake valve is actually quite heavy, so it requires a little more spring and a little softer of a cam ramp to keep it under control. For more aggressive combinations that want to also improve durability, you have to go lighter on the valve side. This will allow you to run a more aggressive camshaft lobe as well as needing less spring to control everything.
Long story short, it is always beneficial to reduce reciprocating mass on the valve side of the equation. It will allow you to run a lot less spring + save every other component from excessive abuse wear
Old 02-01-2023, 12:59 PM   #38
Judy1le
Drives: 2020 SS 1LE
The lightweight or OEM valves breaking? Ill add that the lightweight valves from Katech are also titanium/molybdenum which has a better strength/weight ratio compared to steel (assuming thats what the OEM valves are made of).
Judy1le is offline   Reply With Quote
Old 02-01-2023, 02:24 PM   #39
cvp33
America FVCK Yeah!
cvp33's Avatar
Drives: 2024 Z06
Hood = damn
1997 Z28 Anniversary Edition SOLD
2004 GTO ORDER CANCELLED
2004 CTS-V SOLD
2005 CTS-V SOLD
2006 300C SRT-8 SOLD
2010 CTS-V SOLD
2012 CTS-V coupe SOLD
2013 ZL1 vert SOLD
2016 Callaway Z06 SOLD
2019 Z06 SOLD
2021 ZL1 1LE SOLD
cvp33 is offline   Reply With Quote
Old 02-01-2023, 07:55 PM   #40
SCCAForums
SCCAForums's Avatar
Thanks guys! Been working on logistics to get vehicle picked up and off to Penske Rapid Repair for Anderson Composite Carbon Fiber items, along with tailored rear bumper for the center exit exhaust. Also working with ProParts USA on MCS Double Adjustable w/ Remote reservoirs, along with a miriad of other items to try and get done before 2/25 and we plan to head to Thunderhill the week of the 28th for Optima's Ultimate Street Car first event of the season.
Will continue to share updates as we progress with the build. Can't wait to get her out on track!
Best regards,
Dave
Old 02-01-2023, 08:26 PM   #41
RamAir02
Shadow Gray '19 ZLE M6
RamAir02's Avatar
Drives: '19 ZL1 1LE M6
I met a guy at the track with similar exhaust. You can see it in the beginning of this video
YouTube
Old 02-02-2023, 08:37 AM   #42
Boost Creep
Boost Creep's Avatar
Drives: '18 1SS 1LE
Originally Posted by SCCAForums View Post
Thanks guys! .... Optima's Ultimate Street Car fist event of the season.
Best regards,
Dave
Love the spelling error.
'18 1SS 1LE Black, PDR
anderson composites, forgeline wheels, katech, msd atomic airforce manifold
