#29 | |
Also, in terms of temperature they may crack if flexed under 20 degrees (see below), but if it doesn't get colder than mid-high 20s at night and you wait till later in the morning before driving off, it should be all right.
#30 | |
![]() Drives: '19 ZL1 A10 Join Date: Oct 2020
#31 |
![]() Drives: 2008 Audi RS4 Join Date: Jan 2020
The back end has only twice rotated more than unexpected. Once when it was cold (30’s F), wet, downhill into slow 90 deg intersection left turn and on another occasion doing 40 mph (warm, dry), brake downhill, into 30 mph entry of a 90 bend over rough pavement into uphill. It didn’t take much throttle to upset the rear axle in those scenarios. The back end was probably light already because of downhill braking and asking it to accelerate that little bit was too much to ask. Both required a brief countersteer to correct and a minute to return the heart rate to resting.
When it’s cold and wet, reduce the speed and soften the inputs where you’re asking the tires to turn and accelerate. I would also agree with driving during the day to use the better visibility to avoid on-road hazards at night where you would have seen them much earlier in daylight. The forward lights are not that great at night.
2012 Lexus CT200h Premium Navi
2008 Audi RS4 2004 Audi S4 2018 Chebby Camaro ZLE HMB |
#32 |
![]() Drives: ZL1 Join Date: Jan 2019
All stock and have the PS4S, its spinning in 3rd! pressure set to 225 (32.6).
#33 |
Black lightning
To high try 29-30
[ 2021 Camaro ZLE 10 speed
