Old 01-21-2023, 05:06 PM   #29
ariZona28
Give speed a chance
ariZona28's Avatar
Drives: 2015 Camaro 2LS, 2015 Camaro Z/28
Originally Posted by AZIROC View Post
As of right now, I can't pass sound at amp (headers/borla s-types and cat delete). But I didn't pass stock either. Which sucks cause I'm literally 5 mins from that track. I may try to fab up so.e cheater pipes over the summer. Till then I'm usually at Wild Horse.
Yeah I remember our discussion a while back. Hit the plumbing shop and make some turndowns! Not sure if you've made the journey yet but The Podium Club at Atessa is very nice. Great place for you to wind out that Z and a much nicer facility than old Firebird.
ariZona28 is offline   Reply With Quote
Old 01-22-2023, 12:32 AM   #30
AZIROC
Drives: '86 IROC-Z '18 ZL1
Question
I was on the fence about going to atessa but since there aren't many WHP races this year, I'll prob end up going just to get some seat time.
Old 01-22-2023, 08:31 AM   #31
20Bluezl1
I made some Laguna pipes and they work pretty good.
Old 01-22-2023, 08:45 AM   #32
sr71bb
sr71bb's Avatar
Drives: 2019 Camaro Z-28
Our AMP is Arizona Motorsports Park and they have a 96db sound limit so you don't disturb the jet pilots at the AFB nextdoor. LOL!
Well I have KOOKS headers and MAGNAFLOW mufflers on the back half. We DONT have any restrictions that I am aware of but the last time it was measured at an event I never got above 90DB.
Since I run a large NA engine so I probably have an advantage with noise limitation because I dont have a that supercharger whine to contend with.
You might try playing around with where you are exiting your exhaust. If you had tailpipes that turned down DIRECTLY to the ground just prior to the rear axle that might help keep at least some of the exhaust sound from directly exiting out the sides of the car. Since the DB meters are usually just off trackside this might help. For cosmetic purposes you could run electric cutouts that when closed would allow the exhaust to exit through the normal tailpipe setup thru the rear bumper. Ride Height probably can have an effect on DB emissions. In theory the LOWER you have your ride height, the LESS sound that will escape out the sides of the car. The KOOKS bullet style mufflers are DEFINITELY louder than a MAGNAFLOW type conventional muffer.
Your post reminded me that when I was a kid, the air force and navy would fly planes supersonic over residential areas and it would rattle the dishes . This was the reality in the JFK days. A couple years later they decided that MAYBE was not such a great idea. I lived near the NAVAL AIR STATION in Grand Prairie Texas and CARSWELL Air Force Base which was a Strategic Air Command (SAC) base with a B52 bomber squadron. In schools at this time we would do Nuclear Blast alerts where we would go into the hallways and place our heads between our legs in a duck and cover drill.
The joke later was that all we essentially were doing is kissing our asses goodbye!!!
2019 SS 1LE BIG NA A10
Eagles Canyon Raceway 2.7 CCW Below
https://youtu.be/c9M5UHDftcA
4-15-23 at SCCA TT U1 Class
MEGA Thread on THIS car:
https://www.camaro6.com/forums/showthread.php?t=602092
Retired Cars BELOW:
1973 Camaro, 1969 Camaro, 1969 Camaro SS RS
2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10
sr71bb is offline   Reply With Quote
Old 01-22-2023, 12:38 PM   #33
AZIROC
I'm surprised you only got 90db. My zl1 stock was 101db. Now that I have kooks, no cats and borla, I'm sure I'm past 110db
Old 01-22-2023, 12:39 PM   #34
AZIROC
Pretty much what I'm thinking. I may add those cone shaped "muffler" things inside them as well.
Old 01-22-2023, 01:09 PM   #35
sr71bb
sr71bb's Avatar
Supercharged cars make MORE noise stock than non-supercharged cars. BORLA is louder than MOST exhaust systems I am aware of.
Retired Cars BELOW:
Old 01-22-2023, 01:16 PM   #36
20Bluezl1
I thought about that also but haven't had an issue as is. Also I made them where I can point them to either side so it points away from the sound booth.
