Old 01-31-2023, 01:41 PM   #29
manders500
Drives: 2017 ZL1 Camaro
Just remember that these are for off road use only.
manders500 is offline   Reply With Quote
Old 01-31-2023, 02:19 PM   #30
2023_ZL1-AUTO
2023_ZL1-AUTO's Avatar
Drives: 2023 ZL1
LOL - All the aftermarket parts I've bought came with a special Permit for Ohio... apparently it needs renewed each year !!! LOL
Old 01-31-2023, 09:10 PM   #31
Booher
Booher's Avatar
Drives: 2019 zl1 6 speed
Any update on being able to re install the tunnel brace?
Old 02-02-2023, 04:50 PM   #32
Rleo6.2
Drives: Gen 6 ZL1 Camaro C7 Zo6 Corvette
What size 2 bolt lap joint clamps are needed? All 3"?
Rleo6.2 is offline   Reply With Quote
Old 02-02-2023, 06:09 PM   #33
manders500
Theses do not go up high enough in the tunnel. I did find the Halo Super cars one that fits larger exhaust. I just think that this is a basic kit vs a well bent system. You might be able to call Speed Engineering and just get the front pipes.
Old 02-02-2023, 06:10 PM   #34
manders500
It came with all of them and I did not see any size difference. If you are buying the 2 bolt kind then the 3" will fit the who thing except the connection to the stock muffler.
Old 02-11-2023, 11:28 PM   #35
tomster
RedLine
Drives: 2022 ZL1 1LE
I just got around to installing mine. I'm disappointed in the fit... Hangs much lower, tunnel brace won't fit, Very close to driver side diff cooler lines... (I moved them out of the way). I had cat delete pipes from other companies that fit much better in the past unfortunately you can't buy them anymore.
I did try to install just the front pipes first with no luck
Now for the price of this kit you do get a lot. I just wish they made it fit in the tunnel better.
The kit comes with 8 3inch band clamps and three 2 3/4 band clamps. The smaller clamps go on the reducers at the muffler, and on the driver side at the cat
tomster is offline   Reply With Quote
Old 02-13-2023, 05:34 PM   #36
manders500
I ordered the Halo Super Cars cross brace and loosened all of the clamps and installed the Halo crossmember then tightened all of the clamps. I will weld one of the joints and use the lap joint bands on the muffler side.
The fit could be better but to get the secondary delete and x-pipe for under $400 is not bad.
Old 02-13-2023, 06:20 PM   #37
Rleo6.2
So the Halo cross brace actually fit. I was waiting on a reply from the dealer on how much further the Halo drops below the stock brace. Can you elaborate on the what joints you will be welding and where you are using the lap joint bands ?
Old 02-14-2023, 10:00 AM   #38
manders500
I will weld the x-pipe to the pipes going to the muffler and use lap joints on the muffler. Here is the Halo installed
Old 02-16-2023, 12:05 AM   #39
carbon fibr
carbon fibr's Avatar
Drives: 2021 ZL1 1LE
I had this kit on my 2018 SS 1LE, I also thought it fit poor, cross brace didn't fit as well. After getting it hot you'll have to go back and tighten up the clamps some more. I had issues with it leaking at almost every joint. I could smell exhaust in the car all the time, its an attractive system but going to go a different route with my ZL1 this time. Hope it works out for you guys.
2021 ZL1 1LE Satin Steel Grey
carbon fibr is offline   Reply With Quote
Old 02-16-2023, 08:32 AM   #40
JSH
JSH's Avatar
Drives: '20 ZLE
Originally Posted by Future1LE View Post
Are there any company that still make cat delete pipe that get rid of all 4 cats and still able to work with the stock headers and rest of the exhaust?
We just scraped out the internals of my cats, which leaves only the small cat back mufflers. .
2020 ZL1LE A10.
100 octane: 1045hp/1055tq.
Old 02-16-2023, 10:35 PM   #41
tomster
RedLine
I bought the Halo brace and mine still hangs to low, Unfortunately. No time to work on it for a couple of weeks but I will try to figure out a solution. I'm considering Flatting the section at the brace slightly
Old 02-27-2023, 11:00 PM   #42
driftking123
driftking123's Avatar
Drives: 2022 SS 1LE
How does it sound? I ordered the kit for the second cat delete. I already deleted the second cat, but I saw this and wanted to add a little more sound. Just curious how you like the kit.
driftking123 is offline   Reply With Quote
