#29 |
![]() Drives: 2023 Camaro 1SS 1LE 6MT Join Date: Nov 2023
Very good info, thanks! I'll definitely be using your thread when I get to that project!
#30 | |
We used an audio test CD with frequency sweeps at normalized volume. Set the car for medium to high "system" volume and then measure the electrical outputs at the various speaker feeds to get readings for the EQ and relative volumes. To be honest, I thought the newer integrated gadgets had some kind of calibration mode which did this automatically. |
#31 |
![]() Drives: 2017 2ss Join Date: Jan 2022
So what ever happened with this? I think my passenger door speaker may be blown has the most annoying rattle with any base i plan to open things up and take a look and if I can swap it out with something. If not fix the issue that would be great
#32 |
![]() ![]() ![]() Drives: 2023 2SS Convertible Join Date: May 2009
I bought a door kit from resonix, and all the speakers, adapters and harnesses. It is all still sitting in a pile in the garage. Hopefully a winter project! By the way, I did find out that the GS25 will mount in all three dash locations. That is all the progress I made though.
-Geoff
#33 | |
Electrical Engineer
https://www.youtube.com/playlist?lis...AT4zHytvT3DDXm
1100: 5/3/22 . . . . . . . 2000: 6/25/22 . . . . . .4000: 8/17/22 . . . . . . . 6000: 9/10/22 Daily Driver mileage update: 64k mi. @ Apr 2026 New Engine @ 22,600 mi. due to dealer confusing bad gas with a bad engine. Build Log: https://www.camaro6.com/forums/showt...6#post11353116 |
#34 |
Electrical Engineer
For those looking to understand how to tune a DSP to get your sound system dialed in, i've found this YouTube channel (not mine) to be the most comprehensive resource for how to use REW to fully analyze and tune the system.
https://www.youtube.com/@socketsocket2763
#35 | |
-Geoff
#36 |
Electrical Engineer
Thanks! I'm able to play down to 40Hz in my doors with zero buzzing and enough output to sound like a small sub. All of the materials I use are necessary, not just deadening.
#37 |
Electrical Engineer
Another view of the factory EQ on the 1SS Non-Bose radio. I have access to a LT1 with Bose and will do similar measurements on that system soon.
#38 | |
![]() ![]() ![]() ![]() ![]() Drives: Chevrolet SS 1LE Join Date: Oct 2019
Matt Miller
2020 SS 1LE |
