Old 11-02-2022, 12:48 PM   #29
SebV19
SebV19's Avatar
Drives: 2019 ZL1 1LE
Originally Posted by DaveC113 View Post
You still have the ABS expecting to see the fronts spinning faster vs rears, maybe not an issue with ZLE but definitely a potential issue with non-1LE cars.
Right... and that's my point about maintaining the % height difference front to rear. These cars come staggered and if you want to use the electronics to their fullest extent, you should keep them in their operating range.
2019 ZL1 1LE A10
AP Racing Brakes - MCS/Vorshlag 2WR - MFR Engineering Diffusor + Flat Floor - C&R Oil Cooler + Heat Exchanger - Piper Motorsport Cage - Anderson Carbon Doors + Trunk
SebV19 is offline   Reply With Quote
Old 11-02-2022, 11:58 PM   #30
SoCal Smith
SoCal Smith's Avatar
Drives: 2019 Camaro ZL1 1LE A10
You can always update the tire size in HP tuners!
SoCal Smith is offline   Reply With Quote
Old 11-03-2022, 09:27 AM   #31
Slurpee
Slurpee's Avatar
Drives: 2020 ZL1 A10; Shadow Gray Metallic
Right, that's why I was going with those tires. But all the threads were related to ZLE's, so I was going off of that information, unless the ZL1 and the ZLE ECM's calibration for ABS is the same. The % difference is definitely a bit different than I was anticipating for the ZL1. 305/660/18 F 325/680/18 R is a 3% difference in height compared to stock's 1.9%. There really isn't a tire configuration that gets it closer. 305/660/18F 325/660/18R is a 0% difference. I was using Sport 1 towards the end of the season.
Slurpee is offline   Reply With Quote
Old 11-03-2022, 01:33 PM   #32
SebV19
SebV19's Avatar
You honestly should be more than fine with that setup. If anything just be wary of rear brake temps if you're going to be in those modes.
2019 ZL1 1LE A10
Old 11-03-2022, 02:28 PM   #33
Slurpee
Slurpee's Avatar
Cool, that's what I thought.
zl1, zl1 1le
