Old 10-27-2022, 03:36 PM   #29
Jus Cruisin
Old Gearhead
Jus Cruisin's Avatar
Drives: 2023 GMC Sierra Denali Ultimate
Why not check with a few local bodyshops? That would be right up their alley. I'm sure they are replacing harnesses regularly. At least you'd find out what you cooked.
2023 Camaro ZL1 convertible - black - SOLD
2025 GMC Sierra Denali Ultimate - black - 3.0l diesel
1937 Ford Slantback
Jus Cruisin is offline   Reply With Quote
Old 10-27-2022, 04:43 PM   #30
stormtrooperSS1le
Drives: 2017 camaro ss 1le
Good idea I can ask around, hoping it can be repaired too I’m sure it can be just need to find a person willing.
stormtrooperSS1le is offline   Reply With Quote
Old 10-27-2022, 08:17 PM   #31
stormtrooperSS1le
I’m going to start soldering new wires 4 at a time tomorrow. Needs about 12 redone. Hopefully we’re all good after.
Old 10-28-2022, 08:27 AM   #32
jamala00
jamala00's Avatar
Drives: 2016 Camaro 2SS Hyper Blue Metallic
Good luck... Hope it all works out for you.
jamala00 is offline   Reply With Quote
Old 10-28-2022, 08:54 AM   #33
stormtrooperSS1le
Me too ither wise I’m pulling the motor and procharger and putting a stock motor in and trade it for a vette.
Old 10-29-2022, 03:39 PM   #34
Sephx1
Sephx1's Avatar
Drives: 18 ZLE, 18 SS1LE, 16 SS, 23 ZL1
Looks like the chassis harness, not practical to replace and may not even be available from GM. I soldered every one of them to splice at that same location on a burn salvage vehicle. No issues.
Sephx1 is offline   Reply With Quote
Old 10-31-2022, 11:24 AM   #35
stormtrooperSS1le
Nice man that is my plan as well. My dumbass ordered a chassis harness of eBay so if anyone needs one I have a complete spare harness for the entire car.
Old 10-31-2022, 12:03 PM   #36
SomeGeoffGuy
SomeGeoffGuy's Avatar
Drives: 2023 2SS Convertible
At least you could pirate all the correct color wires out of it. Might make the process less confusing.
-Geoff
'16 2SS Convertible - White on white, mag-ride, NPP, nav. Sold!
'23 2SS Convertible -Same as above except orange.
SomeGeoffGuy is offline   Reply With Quote
Old 11-03-2022, 09:26 AM   #37
stormtrooperSS1le
Ok so I repaired the burnt wires and taped some others that had a small hole. I am still getting service security service suspension and no start condition. Should I check that rear harness in the wheel well too?
Is there a reset I can do?
Old 11-03-2022, 01:54 PM   #38
SomeGeoffGuy
Did you go through the fuses? Might be some blown.
-Geoff
Old 11-03-2022, 02:24 PM   #39
stormtrooperSS1le
I’ll go through them again, I have hptuner I am going to try and disable the theft system. I heard that you can do this and it gets rid of it.
Old 11-03-2022, 02:29 PM   #40
jamala00
jamala00's Avatar
Ya... I think I said earlier in this thread... what happens if you fix the wires and there are still issues. Do you have the tools/scanners to resolve the problems. Hope you get it sorted out. I know my post is of no help... If nothing else, maybe you can put it on a flat bed and have a dealer resolve the codes now that you fixed the harness? (Just an idea)
Old 11-03-2022, 07:56 PM   #41
stormtrooperSS1le
Here is what I pulled from hptuner. Assuming these are redundant based on one major issue being the wiring. I can clear these but they come back. I will check fuses tonight in trunk and engine.
Old 11-03-2022, 09:04 PM   #42
stormtrooperSS1le
Fuse 47 cgm fuse was blown going to replace and report back. I needed to order new fuses. Misplaced my old replacements.
