Old 09-20-2022, 09:57 PM   #29
keep_hope_alive
Electrical Engineer
keep_hope_alive's Avatar
Drives: 2023 1SS A10 Black
I did just order the ZL1 Addons Lift Pads after looking at the jack point locations. My Honda and Toyota had pinch weld reinforcements that created a stronger, reinforced spot. These pads look awesome.
Daily Driver mileage update: 45k mi. @ Mar 2025
Old 09-20-2022, 11:53 PM   #30
2SS Capt
2020 Shadow Gray 2SS
2SS Capt's Avatar
Originally Posted by Gen6cyl View Post
I have heard good things about quick jacks . I grew up in Atlanta, been in country almost 30 years.
Originally Posted by 22SS1LE View Post
id like to eventually get a quick jack. but who knows when that will be
LOVE my QuickJacks...
Old 10-06-2022, 07:09 AM   #31
Gen6cyl
Drives: Chevy Camaro 2021 ,rs, v6, manual
Very sano , like a operating room.
Gen6cyl is offline   Reply With Quote
Old 02-07-2023, 08:46 PM   #32
truckrglenn
truckrglenn's Avatar
Drives: Chevy camaro
Which model Quickjack? The 5000TL looks good or should I order the 7000TL?
Glenn
SOLD - 2017 Camaro 2LT RS Convertible
2017 GMC Arcadia Denali
truckrglenn is offline   Reply With Quote
Old 02-08-2023, 12:24 PM   #33
2SS Capt
2SS Capt's Avatar
The 5000 has plenty of capacity for the Camaro...
Old 02-08-2023, 04:04 PM   #34
keep_hope_alive
Electrical Engineer
The 5000TL is a future desire. For now, i'm happy that I can lift the entire side at once. The lift points are handy. I do have a jack pad and some extra rubber pads that allow for clearance with the floor jack and body. It's kind of silly.
Old 02-09-2023, 04:10 PM   #35
haggler
haggler's Avatar
Drives: '23 2SS RSblue 6MT, sold '19 ND2
Did my skip shift eliminator and oil change. I used those aluminum pinch weld adapters stacked on top of a hockey puck to lift. My harbor freight jack's saddle barely clears the rocker panel if the puck sits as close to the edge of the saddle as possible. I wanted to get the zl1 addon lift points but I dont want them permanently attached to the pinch weld, and amazon doesnt sell them individually. I don't like lifting really high on one side but had to for the skip shift eliminator. Expanding a 90 degree pliers helped unplug the connection, otherwise I wouldn't have been able to do it given the angle and tight space.
'23 2SS, 6 speed, NPP, Copper-free brakes, 56V Carbon Flash Rims, Riverside Blue
1LE sway bars
EOS front splitter
5-6-22:1100,
7-19-22: 3000,
8-3-22: TPW 8/15/22,
10-4-22: ETA 10/13/2022
10-15-22 6000
haggler is offline   Reply With Quote
Old 04-25-2023, 04:18 AM   #36
PhotoGuy
PhotoGuy's Avatar
Drives: 2020 Camaro 2SS .. chevy silverado
Is the cross member behind the diff. a safe jacking point?Anybody
yes you can jack your camaro from that rear support .... done it many times with no issue ....
PhotoGuy is offline   Reply With Quote
Old 04-25-2023, 08:08 AM   #37
302crossram
302crossram's Avatar
Drives: 2023 Sharkskin 2SS
I have used the rear crossmember lift point with a hockey puck
works great.
when raising on the pinch welds, I have the missus lift the other side while I'm
lifting my side, 2 floor jacks (zl1 lift blocks installed)
Old 04-25-2023, 03:57 PM   #38
eldersCAMARO
CamaroLove
Drives: 2023 ZL1 Shark Skin
this may be a stupid question but to use a lift instead of jacks, can you lift the entire car with the zl1 add-ons with hockey pucks from the lift points on the furthest points in the front and furthest points in the back?
Just want to make sure I installed it at the perfect points.
eldersCAMARO is offline   Reply With Quote
