#29 |
![]() Drives: 2022 2SS Join Date: Mar 2022
Since you / they have to replace one rocker panel, put a set of ZL1 rockers!
2022 Camaro 2SS (6000 Vehicle Delivered to Customer 4/7/2022) Build Date 2/28/2022 GAZ Summit White B04 Black Metallic Rally Stripes IOT Navigation MX0 A10 Transmission CF5 Power Sunroof SLN Strut Tower Brace 56V 20" 5-spoke Carbon Flash Metallic Wheels NPP Dual-mode exhaust VTD 2nd Gen Ground Effects Carbon Flash Metallic 1996 Corvette LT4 Convertible Collectors Ed SOLD 2004 Corvette ZO6 LeMans Commemorative SOLD |
#30 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2020 Camaro 2SS A10 Join Date: Jun 2018
"Never assume anyone else knows how to drive." Which is how I drive, I assume everyone is an idiot except me, and drive accordingly to account for stupid. I can't fix stupid but I can anticipate it.
#31 |
Drives: Chevy Camaro 2021 ,rs, v6, manual Join Date: Feb 2022
I love it when a vehicle is at a stop sign and inches for ward as you approach.
#32 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 1SS 6spd Join Date: Jan 2011
Don't let them bum rush you into anything else. And if necessary mention how your neck has gotten "really stiff" since the guy with all the front end damage impaled your new car!!!
#33 | |
![]() ![]() Drives: 2004 BMW 330CI, 2022 1SS 1LE Join Date: Dec 2021
Basically the entire rear axle/right wheel took the impact but the body is mostly intact. I am a little worried about some long term damage to the differential though. I'm going to make sure they replace the rear bearing too. We will see, fingers crossed everything works out. If they get everything fixed before October NASA @ VIR I'll give the car a good shakedown then. |
#34 |
I'm sure you're aware of the separate rear sub-frame that our independent suspension requires and Chevy's extensive use of aluminum, and other light weight materials. The rear suspension components are made to absorb (bend) rather than transmit the loads imposed on them by forces they are not intended to deal with while driving- IOW, find the body shop that appreciates the complexity of this repair and if they are not able or willing to double check every aspect of potential damage, look elsewhere. Do not limit your search to the 3 shops they prefer. That's a mistake I made as a young man with my '86 Z. Don't let'em just make it look pretty again! (It is a really nice looking car!)
Obviously you're going to need a 4 wheel alignment besides new body panels and paint. Along with a new wheel and tire, and anything else you see has damage- no Bondo! My wife's Subaru got smacked the same way and it snapped the rear wheel right off the axle It was considered totaled. Good luck and remember that while the insurance company might balk, you've got'em over a BIG barrel. And be sure and let them know you're gonna need alternate transportation for the duration of the repair- something with a nice ride so as not to jar that ever worsening neck!
#35 | |
