#29 | |
#30 |
![]() ![]() ![]() Drives: 2020 LT1 M6 Join Date: Jan 2016
#31 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Mosaic Bk ZL1 M6 Join Date: Jul 2009
It's not really that confusing until you get on camaro6
#32 |
![]() ![]() Drives: 2021 LT1 6spd Join Date: Nov 2020
Yes. The owner's manual is clear.
Current: 2021 LT1 Camaro, 6spd, Crush, Corsa NPP, GMPP CAI, Soler Performance Throttle controller
Previous: 1997 V6 Camaro, 5spd, Black |
#33 | |
Also, this isn't the only topic of a similar nature, just check out the 'does the ZL1 1LE ride too rough for a daily' threads with the endless debates, or our infamous catch can sagas. They're like slightly different channels from the same provider
#34 | |
#35 |
Oldman w/a teenager brain
Drives: 2022 ZL1 A10 Join Date: Mar 2021
Don’t worry about the loud mouths here OP. Every subject has been brought up numerous times. It’s a forum. Its how they keep going. They just like their high post count. Makes them feel special.
#36 | |
#37 |
![]() Drives: 2016 Camaro SS Vert. Join Date: Apr 2017
#38 | |
![]() Drives: 2017 2SS F1FTY Join Date: Feb 2020
2017 2SS F1FTY/HUD/Mag Ride/NPP/Nav/M6/Mishimoto catch can/BTR stage 2 Cam kit/GPI ported LT2 IM and 95mm TB/Roto Fab CAI/Kooks Long Tubes ceramic coated/Borla S Type NPP catback/AFE lowering springs/1LE wheels/OEM smoked tail lights/Diode Dynamics side markers/Uniden R7/3D Maxpider floor mats/Adams graphene ceramic coat
#39 |
Drives: Chevy Camaro 2021 ,rs, v6, manual Join Date: Feb 2022
710 oil sounds good to me.
#40 |
![]() Drives: 2018 Camaro SS A8 "Dark Knight" Join Date: Oct 2019
GM dexos2™
GM dexos2™ oils are Top Tier lower SAPS¹ lubricants designed for use in high performance gasoline and light duty diesel engines where advanced aftertreatment systems such as Diesel Particulate Filters (DPFs) are used. GM dexos2™ oils are typically high HTHS (≥ 3.5cP) SAE 5W-30 and 5W-40 based on API Group III base oils. The main physical and chemical requirements for GM dexos2™ oils are shown below: Requirement Method Unit Limit HTHS viscosity CEC L-36-A-90 cP ≥ 3.5 Sulphated Ash ASTM D874 %wt ≤ 0.8 Phosphorus ASTM D4951 mg/kg 700 to 900 Sulfur ASTM D4951 mg/kg < 3500 Evaporation loss (NOACK) CEC L-40-A-93 % ≤ 13.0 Total Base Number ASTM D2896 mgKOH/g ≥ 6.0 Note 1: SAPS refers to Sulphated Ash, Phosphorus and Sulfur, the levels of which are often restricted in the latest performance specifications. GM dexos2™ is usually coupled with a range of different combinations of other approvals depending on the viscosity grade of the lubricant, The most frequently seen approvals claimed in conjunction with GM dexos2™ being ACEA C3, BMW Longlife-04, Volkswagen 50500/50501, Porsche C30 or A40 (5W-40 only). For more information on GM dexos2™ oils, contact your Lubrizol representative.
DARK KNIGHT
2018 SS A8 11.37 @ 121.01 GPI Tuned E85 Nitto tires Roto Fab CAI MSD intake |
#41 |
Thank you Al Oppenheiser!
Congratulations, you now own a "big wallet car"
![]() Yep, that's right you heard it here first: Welcome to the $10/quart oil club !
#42 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 23 ZL1 A10 Rapid Blue Join Date: Aug 2020
Which CAI produces the most power?
| Tags |
| dexos2, oil, pennzoil |
