Old 07-11-2023, 06:14 AM   #29
Smokin19
Drives: 19' ZL1 A10, w/pdr
That's quite a change in your plans but, I am sure you have your reasons. I went the Kong X-port and have been very pleased with the results.
On another note I have two friends that installed the same Whipple you have and had problems. They both ended sending them back to Whipple to be fixed (still waiting ). Not real sure of the problem but both said the SC sounded like it had marbles rolling around in them.
Smokin19 is offline   Reply With Quote
Old 07-11-2023, 07:33 AM   #30
Crusher Camaro
Drives: 19 ZL1
Originally Posted by 55chev View Post
why the change of plan?
fuel system, really tired of calculating E85 content.
If I firm up the low side and add port injection, I can just fill up on E85.
Fuel pump, port injection, port the stock blower and pulley down a bit plus the tune will get me in the 800whp range. plenty.... for now.
Crusher Camaro is offline   Reply With Quote
Old 07-11-2023, 07:36 AM   #31
Crusher Camaro
Drives: 19 ZL1
Interesting, I know the 5gen LSA had a sound issue from the drive coupler.
not sure what type of coupler Whipple used on the 2.9.
Old 07-11-2023, 12:59 PM   #32
2023_ZL1-AUTO
2023_ZL1-AUTO's Avatar
Drives: 2023 ZL1
Awesome Job !!!! Enjoy that Bad A$$ idle !!!!! and power !!!!
Old 10-04-2023, 06:45 PM   #33
Crusher Camaro
Drives: 19 ZL1
Little update.
so I ended up keeping the whipple 2.9 and installing it, added a Katech 103 throttle body and big gulp.
Install was easy, little extra time spent routing valve cover breather lines to the catch can and moving the intercooler line around for clearance. with the whipple intercooler connection it was easy to replace the hard aluminum pipe from the passenger side over to a rubber hose and rerouted it to mount my catch can.
using 3.5 pulley with the 8% overdrive lower, making 15-15.5 psi.
basically maxing the fuel system out on pump gas.
pretty much wrapped up the tune with Ted, finishing up a couple of minor tweaks.
definitely picked up some steam, car pulls hard all the way to red line. will get on the dyno again in a few weeks and see what the difference is from before.
Whine is real, even at idle you can here it whistling away.
quick idle video while I was bleeding air out of the coolant system.
https://youtu.be/xXxZfT0Qke8
Old 10-04-2023, 07:55 PM   #34
Jetrep
Jetrep's Avatar
Drives: ZLE, IROC, Bolt, Square, D-max
Originally Posted by Crusher Camaro View Post
Little update.
She sounds pissed and looking for a fight!!!! Got me think about tearing into my zle.
Jetrep is offline   Reply With Quote
Old 10-05-2023, 09:57 AM   #35
SOCAL.M6.ZLE
Having FUN in the SUN...
SOCAL.M6.ZLE's Avatar
Drives: 2022 M6 ZL1 1LE
Congrats, what a sexy build! Can't wait to see your numbers!!!
Old 10-05-2023, 10:34 AM   #36
Tim M
Tim M's Avatar
Drives: 2018 Camaro SS 1LE
Congratulations - we know of the work that goes into (rebuilding out LT1 currently). Kudos to a job well done!
Tim M is offline   Reply With Quote
Old 10-05-2023, 06:44 PM   #37
Crusher Camaro
Drives: 19 ZL1
the fight is now the stock Goodyear Supercar 3's.
warmed up and on a warm day. they are ok.
anything less and we spinning.
set of billet specialties drag packs on my list with a drag radial. add to my coming soon.
yeah, me to, will get on the rollers in a few weeks.
Thanks, its fun to play with, expensive, but fun.
