#29 | |
![]() ![]() ![]() ![]() ![]() Drives: 2023 CT5 Blackwing, 2025 C8 Z07 Join Date: Sep 2016
It's been changed. At least on the Blackwing, It's now two different selections. There is a rocker switch on the bottom right of the steering wheel for PTM. And a nice, 'V-mode' button which is user-configurable for drive mode and PTM settings.
2017 HBM SS 1LE
Sold 2023 Wave Metallic CT5-V Blackwing M6 2025 Hysteria Purple C8 Z07 |
#30 | |
Pull your OEM tune and look at the throttle tip in tables. They ramp far faster in Tour/Sport than in Track. Track has a much more linear ramp rate.
2017 HBM SS 1LE
#31 |
![]() Drives: 2003 Monte Carlo SS SLP, 2022 ZL1 Join Date: Aug 2021
#32 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '21 ZLE A10 Join Date: May 2012
throttle "tip in" (in my understanding) is only the initial throttle application and not the entire scale/sweep. Overall, I feel the throttle is most aggressive through the entire sweep in track. I suppose GM made throttle modulation a little less touchy there for smoother throttle while on track. I will look at my tables and thanks for clarification.
#33 | |
![]() ![]() ![]() ![]() Drives: 2018 Camaro ZL1 Join Date: Aug 2018
GM couldn't do it with the Camaro since there are buttons already there behind the steering wheel. They could have by either getting rid of those buttons or (my preference) get rid of the heated steering wheel and where the button is for it to put a track mode button there. Then we could have had a customizable track button. |
#34 | |
![]() Drives: 2022 ZL1 1LE Join Date: Apr 2019
You have to do this at speed (not sure what speed it is activated), but if you are standing still, or at carpark speeds it appears to feel like 'tour' |
#35 | |
I changed the steering from tour to sport to track and back while driving at 55 mph. The steering changed accordingly (because I moved the car from lane to lane with some effort). I also did this with the suspension and I could feel it change since the roads were bumpy. Maybe the ZL1 1LE is different but I don't see why but GM did change up the eLSD and trans calibration so maybe they did. |
#36 |
Not trying to be a dick, but when you say PTM modes, you are actually referring to double tapping the traction control button twice while in 'Track' mode right? I just am having a hard time with your findings, as are other guys who drive at the same track as me.
Just to confirm.... 1. Select TRACK mode on center console 2. Select 'tour' on steering effort 3. Double tap the traction button on center console and activate PTM (dash display shows various options). 4. Steering will be automatically set to the heaviest setting. |
#37 | |
I understand you're questioning but I literally did this the day I had to go for an hour drive somewhere. As I said. I entered all PTMs doing this.... Open drive settings on infotainment screen to steering and verify its on tour Select track on mode selector Double tap traction control Select PTM 1, 2, 3, 4, or 5 with mode switch on center console Press ok on steering wheel Verify that traction control icon appears and cruise control icon disappears Test steering input Yup, it's in tour Change to sport Yup, it's in sport Change to track Yup, it's in track Then do the same for the suspension. Again, all done while going 55 mph and changing lanes for the steering input or feeling the road for the suspension input. I had PDR going but I know it doesn't show selected steering input nor suspension settings but I'll look at it later. Comp mode acts the same way too. |
#38 |
I only have a sample size of two cars but both a standard 2017 ZL1 and a 2021 ZL1 1LE behave exactly the same. My two cars behave just like Vigilante375's which I believe is GM's intended programming. No idea why there would be any deviation unless the Canadian thing makes a difference. My quest is solely for accurate information here.
#39 |
![]() Drives: '19 M2C / '19 ZL1 Join Date: Aug 2021
#40 |
I just noticed one step that I am not doing....
Pressing OK on the steering wheel. Shit, could this be the hidden gem I've been looking for? I'll try later today. |
#41 |
I always pressed ok on the steering wheel but I think once you made your selection on the screen, after a few seconds it'll auto select that mode you had selected. I think.
#42 |
Well. I give up. No steering love here. PTM = track steering resistance in my world regardless of what I do.
What can I say? |
