Old 09-12-2022, 10:25 AM   #29
JamesNoBrakes
JamesNoBrakes's Avatar
Drives: 2SS 1LE
Originally Posted by Briland_1LE View Post
I don't see why adding downforce to the rear and not the front on our cars is pointless. The weight bias of the chassis means the front is heavier by a few hundred lbs so adding downforce to the rear would bring it closer to 50/50 weight distribution.
Because the engineers have already balanced this out with the splitter and considering the power and tires/traction of the vehicle in question. Moar is going to slow you down without adding enough downforce benefit to increase track times. The new GT3 RS is a good example of all of these tradeoffs. They've taken this to the extreme. It *only* goes 184, but it goes a lot faster through turns than lesser 911 models. It has active aero so all the downforce doesn't create too much drag when it's not trying to stick to a turn.
2018 2SS 1LE
2023 Colorado ZR2
2022 Stinger GT-line AWD
JamesNoBrakes is offline   Reply With Quote
Old 09-12-2022, 01:19 PM   #30
mRahmani
Drives: ‘23 SS 1LE
Engineers worked on the wicker bill, too. It was an optional add on for the 5th Gen Z/28 and made a noticeable difference there. I don’t see why it would be pointless on the 6th gen.
2023 2SS 1LE “Red Hot”
Built 7/14/22
Delivered 8/27/22!
mRahmani is offline   Reply With Quote
Old 09-12-2022, 04:45 PM   #31
ATl_1LE
Drives: SS 1LE
I ran a few events stock at RA and installed the extended bill and compared. I lost ~1.5mph at end of the long straight but i also gained enough down force into t1 to wot earlier making up most of the difference in first section.
It for sure adds more drag then downforce but for me both are minimal enough not to stress about. If i go the route of adding a front splitter the bill is getting ripped off and proper wing installed.
ATl_1LE is offline   Reply With Quote
Old 09-12-2022, 11:23 PM   #32
Mountain
Mountain's Avatar
Interesting. Any speed degradation going into other corners?
I’m curious if the ZL1 rear wing (not 1LE) does anything beneficial…
Old 09-14-2022, 02:12 PM   #33
Briland_1LE
Briland_1LE's Avatar
Drives: 2020 Camaro SS 1LE
I'm a mechanical engineer and I have performed CFD for the aerodynamics of race vehicles. A wickerbill is not a pointless modification it is actually well documented as being worth while for making downforce in a cheap and easy way. And using downforce to "balance" front to rear weight distribution is a common thing as well. Front heavy car & downforce at rear = more balanced front to rear. Ofc then you will have a different F/R weight balance at different speeds which needs to be considered.
Briland_1LE is offline   Reply With Quote
Old 09-15-2022, 05:44 PM   #34
pbsinternet1le
pbsinternet1le's Avatar
Drives: 2017 1le current /2015 2ss 1le sold
More down force at the expense of drag does not guarantee faster laptimes..
2017 1LE Hyper Blue
pbsinternet1le is offline   Reply With Quote
Old 09-15-2022, 10:27 PM   #35
mRahmani
Drives: ‘23 SS 1LE
No, it will vary from track to track. Tracks with shorter straights will almost certainly see improvements with the spoiler, while longer tracks will need data logging to compare.
Built 7/14/22
Delivered 8/27/22!
Old 09-15-2022, 11:03 PM   #36
JamesNoBrakes
Drives: 2SS 1LE
Then hopefully you'd know the difference between an airfoil and a spoiler. A wickerbill is a spoiler. Does it add some downforce? Inevitably, but the small spoiler on the 1LE is obviously attempting to attenuate the lifting-body of the car in a way that does not dramatically increase drag, as a bigger spoiler would. Separation drag is the highest form of drag and a wickerbill will basically give you the worst drag possible. It will basically be giving you mostly separation and not downforce. You could also use a wing, however, a wing won't spoil the lift of the lifting body, it's obviously a balance to find out what works best. Wing will add some drag and some downforce, but with the small 1LE spoiler, we aren't changing the shape all that much or adding all that much drag. I trust that the chevy engineers worked this out to be the best compromise. Sure, you might be able to find a track where another shape/size is a better compromise, but that's why these are all compromises. Even OEM, they offer a lot of crap that doesn't increase performance, as dealer-add-ons and cosmetic stuff. Yes, you can increase performance with this car, just that every thing you do has an effect and rarely are any add-ons all positive or stand-alone. My industry is aerospace.
2018 2SS 1LE
2023 Colorado ZR2
