Old 06-21-2022, 10:43 AM   #29
JSH
JSH's Avatar
Drives: '20 ZLE
No...38% is max with LT4 pump.
Have you ever measured/mic'd the fuel lobe while the cam was in the LT4 engine? I want to be sure what HPE installed because they won't disclose such.
2020 ZL1LE A10.
100 octane: 1045hp/1055tq.
Old 06-21-2022, 05:55 PM   #30
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
The more then likely used a 32% lobe. That was the most common size used with LT4 fueling.
Old 06-21-2022, 07:53 PM   #31
JSH
JSH's Avatar
Drives: '20 ZLE
So I have assumed, but I would sleep knowing for sure.
2020 ZL1LE A10.
Old 06-22-2022, 01:04 AM   #32
swisstyphoon
Former GM Technician
swisstyphoon's Avatar
Drives: 2018 ZL1 A10, 06 Silverado Duramax
Same procedure works in the car, you can even measure on the fuel pump lifter, but that one might need a little help to go back down without a spring.
https://youtu.be/CcSAKKld5y4
2018 Camaro ZL1 A10
Rotofab Big Gulp, Nick Williams 103, Magnuson 2650, 9.17" (14%) lower, 90mm upper, Vengeance Racing Heads (LME) Cam Package (Cammotion Stage 1), Johnson Lifters, DSX dual intank pump, Lingenfelter high flow check valve, Motion Raceworks Flex Fuel adapter, LPE Big Bore Hpfp, XDI 30% Injectors, BBK shorty headers, Custom 2.75" down pipes, Gesi Gen2 high flow cats, MM catch can.
2006 Silverado Duramax Diesel
MPI Compound Turbo
40% over Injectors
Efi Live DSP5 Tuning
Follow me on Instagram: SwissZL1
swisstyphoon is offline   Reply With Quote
