10-08-2022, 06:51 AM | #29 |
Asking for a friend, if you already have HPT why would you need to have a draggy thingy. When I log I can see the times for a run from 40 to 120 plus all the other data I'm looking for on the pull. I suppose if you don't have HPT it's a useful tool. Just asking for a friend as I stated above.
10-08-2022, 07:56 AM | #30 | |
Not sure if HPT can measure distance-based things like 60ft and 1/8 or 1/4 mile, but dragy can. Although i cant launch from 0 on the street so that functionality is limited usefulness for me. Some are successful like KingLT1 with that. It isnt a major issue, but its GPS based too so it will not be thrown off by tire size changes or other things. Gives me DA and g force too. Although im somewhat suspect of the DA numbers., and g force is pretty squiggly. Would be nice if they showed a gforce average too. Not sure if that squiggly line is actually the variation in gforce on a run, or just some artifact of thier calcs. For HPT, do you manually calculate a run, or is there a function you can set up to show those times automatically? If so, that would be helpful. Dragy is not a requirement for tuning, but it is cheap, reliable, and just entertaining for me.
10-08-2022, 08:14 AM | #31 | |
10-08-2022, 08:27 AM | #32 |
About $160.
10-08-2022, 09:32 AM | #33 | |
Here is an example of the digital slip it gives you after a run.
2016 NFG 1SS A8
10-08-2022, 09:52 AM | #34 | |
Drives: Chevrolet Camaro LT1 Join Date: Sep 2022
I am looking for a way to reduce the traction control effects I am getting on the street (not track or drag strip) with the OEM run flat tires with my Magnuson 2650. Are you running OEM tire size in the Nittos? Or? How wide can you go, or more realistically, how wide is appropriate with the stock LT1 suspension and fender clearances? Will the Nitto 555R2 has reasonable ability to handle rain and cold temperatures? (MY car would not be used in really cold or really slippery weather) How much tread life would I be giving up compared to OEM run flats or Michelin PS4S? Jim G |
10-08-2022, 09:57 AM | #35 | |
2016 NFG 1SS A8
10-08-2022, 11:10 AM | #36 | |
10-08-2022, 11:15 AM | #37 |
Are there more than one Manufacturer of the dragy? If so, what are people running?
10-08-2022, 12:37 PM | #38 | |
Are the 3-dimensional areas around the rear wheel assembles identical on the LT1 and the SS? Jim G |
10-08-2022, 12:52 PM | #39 |
Just another sanity check:
My OEM 245/40-20 tires have a nominal sidewall height of 245*0.40 = 98mm. The 305/35-20 Nittos tires have a nominal sidewall height of 305 * 0.35 = 106.75 mm The extra height of only 8.75mm is I am sure inconsequential from a clearance perspective. BUT, the 106.75 sidewall height creates a tire with a nominal diameter of: 20 + 106.75/25.4 + 106.75/25.4 = 28.0 inches The OEM 98mm sidewall height creates a tire with a nominal dimaeter of: 20 + 98/25.4 + 98/25.4 = 27.7 This makes for a modest 28.0/27.7 -1.0 = 1.1% unintentional gearing change (1.1% "taller" gearing). That is not enough to upset the ECU when either the ABS system or the traction control system compares the OEM front tire rpm with the Nitto rear tire rpm, right? Jim G |
10-08-2022, 12:54 PM | #40 | |
2016 NFG 1SS A8
10-08-2022, 12:56 PM | #41 |
Drives: 2017 Chevrolet Camaro ZL1 M6 Join Date: Jul 2020
Nope. Dragy is the only manufacturer.
JRE Terminator Rough Idle Cam
Magnuson 2650 - 15% lower, 90mm upper FIC+30% DSX Flex fuel/Low side NW 103mm TB/Roto-Fab CAI Monster S Series Elite E2-X 2" TSP LT's BMR:BK063, BK060,TCA061, UTCA060, UTCA063 Weld Beadlocks/17" NT5R2 |
10-08-2022, 12:58 PM | #42 | |
:( Jim G |
