#29 |
L8ap3x
#30 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: Wild Cherry LT1 Join Date: Dec 2016
Easiest way for me to get the car relatively level and have enough room to work: Back car down an incline, place ramps behind rear wheels, place a small level on the window sill, back up ramps.
#31 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2022 CT4-V Blackwing Join Date: Sep 2013
Just did the same. Put the ramps at the bottom of garage lip and backed up them a bit until I can fit under. It was level enough to do the job.
2013 Camaro SS 1LE - Black - M6 - Sold 2016 Camaro SS - Mosaic Black - A8 - Sold 2017 C7 Stingray - M7 Coupe - Sold 2019 C7 Grand Sport M7 Vert - Sold 2021 Camaro ZL1 - Black - A10 - Sold 2019 Tesla Model 3 2022 CT4-V Blackwing - M6 |
#32 |
[QUOTE=Christian1LE;11179284]I have a couple of videos that might help you, first one is just to show the jack points, and the second video shows the DIFF fluid change (I use a Quickjack + Jackstands). Good luck. I tried to make them to the point w/o any fluff.
Thanks for the great videos. I just did the diff fluid on my 2021 ZL1. Nasty sludge on both plugs with only 2500 miles. That is some expensive fluid, $26.33 per quart on Amazon. Has anyone done multiple changes and noticed if the sludge stops building up?
#33 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: like an old lady Join Date: Jun 2012
i have changed mine several times (annually). the sludge hasn't stopped yet. ive made a few posts in the trans section about it.
#34 |
Interesting, I guess these gears just continue to wear hence the two magnetic plugs. Good call on changing this annually. I am surprised it is not recommended to do so in the manual.
#35 |
![]() Drives: 22 2SS 1LE Join Date: Mar 2022
#36 |
Good call.
#37 |
![]() ![]() ![]() ![]() ![]() Drives: 20’ Chevrolet Camaro 2SS 1LE Join Date: Jan 2009
That’s too much work for differential oil swap. I jus lay a piece of cardboard under the rear of the vehicle and use a ratchet and extension, a small oil pump, 30 min later done. No jacks no lifting the car. Not that hard unless your pushing over 200 Lbs. and can’t fit under the car.
