#29 | |
![]() But, the diameter of the OEM lower pulley remains under debate. I believe it's either 7.87 or 8"
2020 ZL1LE A10.
LME LT4 390 short block, LME CID Heads, Kong E2650, FBO. 15" conversion, MT ET Street R 325/15. 100 octane: 1045hp/1055tq. 100 octane + Meth (1x10+): 1117 hp/1067 tq |
#30 | |
![]() Drives: 2019 ZL1 Join Date: Oct 2020
#31 |
![]() ![]() Drives: 2018 HBM ZLE Join Date: Aug 2017
I have the stock lower pulley somewhere in the garage, pretty sure it's 8". Here's a list from ati on their pulleys for reference
#32 |
#33 |
In my calcs for sizing the upper for my coming 2650, I used OEM 8" and 8.8" as my current "10% lower."
2020 ZL1LE A10.
#34 |
Thank you Al Oppenheiser!
Not sure a completely stock fuel system on 91 can get 650whp at altitude, even with the overdriven blower. However... presuming the cam kit includes the extra lobe for the HPFP, you can probably get to whatever the stock LP pump and injectors can give. Easy enough to add a JMS until you hit the injector limit, and then you can always drop the coin for the +30s or whatever later. Suggest you confirm which fuel lobe they're doing and what the implications are for you down the road.
What are you going to use the car for, and is MAT & intercooling going to be an issue for you?
#35 | |
![]() ![]() ![]() ![]() Drives: 2019 Chevy Camaro ZL1 M6 Join Date: Jul 2019
#36 | |
That being said the car would overall perform better on stock cam, bolt-ons, fuel system, and E60... vs cam, bolt's, and 91 octane.
#37 |
You won't see 700 actual in COS with the build shown in your first post. Again, you don't need a 103mm with it either.
2020 ZL1LE A10.
#38 | |
With my current mods, I don't need a fuel system upgrade do I? I figured since I'm not pushing for crazy numbers that I wouldn't need an upgrade with that...am I mistaken? Really just trying for basic bolt on + cam lmao. |
#39 | |
![]() Drives: Z06 Join Date: Oct 2021
#40 | |
What do you mean exactly by high side support? Also what do you mean by "utilizing" the cam? Do you really think the smaller pulley, LT's W/X-pipe, and intake would get me 700whp uncorrected? |
#41 | |
#42 | |
Corrected and accounting for altitude I understand that I'd be less. Does that make sense? |
| Tags |
| cai, cam, headers, mods, street build |
