Old 05-16-2022, 10:15 PM   #29
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
Originally Posted by synolimit View Post
go to a shop and run on a dyno using the uncorrected factor. ask someone in say florida using uncorrected also with the same mods or whatever. that'll tell you the difference. however its not just about altitude so it'll be impossible to tell really but you could get close.
My 15 Z06 made 476 uncorrected and 553 corrected when I was in casper wyoming which is slightly less then denver as far as elevation.
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90
Old 05-16-2022, 10:20 PM   #30
Snowwolfe
Drives: CTV5 V Blackwing on order
Seems a lot of you are arguing over nothing. Isn’t the end result losing roughly 3% for every 1,000 foot of elevation?
Snowwolfe is offline   Reply With Quote
Old 05-17-2022, 12:31 AM   #31
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
No one is arguing. It's Close yes. I was just clarifying that 1 mile up, I lost roughly 14% at same elevation as denver, not 20%.
Old 05-17-2022, 06:22 AM   #32
7LitreC5
Drives: 18 Tahoe RST, 19 Z06
I've used 20% here today. Madcap in Lakewood told me they use 26%
I could easily see that on a 90-something degree day with humidity at our altitude.
7LitreC5 is offline   Reply With Quote
Old 05-17-2022, 07:38 AM   #33
wnta1ss
Drives: 2017 Camaro 1SS
Dyno correction factors, which some guys are quoting, do not take whether the motor is NA or supercharged or turbo into account. This is a flaw which should not be overlooked. Another thing, the dyno correction factors were originally meant to account for different days in the Detroit area, like plus or minus 3% or so, and therefore they are not really in their intended range any longer when they are spitting out 20% corrections.
Here is another clue about NA vs supercharged at higher elevation, dragstrip ET correction factors for 5800 foot elevation (like the Bandimere track near Denver):
modded NA elapsed time correction factor is .9405
modded SC elapsed time correction factor is .9702
This smaller handicap for the supercharged motor shows us that the supercharged motor is not expected to lose as much power from the thinner air as a normally-aspirated motor is. Lose something, yes, just not as much.
If you REALLY wanted to know how much hp you've lost, you'd need to modify synolimit's dyno idea, by using a dyno on a trailer up there, printing both corrected and uncorrected sheets, then drive both that dyno and your car to low altitude and repeat the test. Same dyno, same car, high vs low altitude in other words. Look to see how much the actual hp at the 2 altitudes changes, and also what happens with the corrected numbers. Based on supercharged dyno sheets from high altitude that I've seen posted, I think you'd find that you did not really lose quite as much hp up there (actual vs actual) as the dyno CF seems to indicate.
Old 05-17-2022, 08:16 AM   #34
JSH
JSH's Avatar
Drives: '20 ZLE
Most of us here can discuss such matters without attacking those who have a different opinion.
Yes, 2.5 to 3% for every 1000 ft. of density altitude is pretty close for discussion purposes.
This topic has been discussed here a lot. I agree, and as Dyno Jet told me last year, a dyno is intended to measure the power output of a particular car/build in a particular city and is not intended to make an accurate correction of that car's power in Denver to sea level.
Bone stock ZL1s up here are around one second slower than Chevy advertises.
2020 ZL1LE A10.
100 octane: 1045hp/1055tq.
Old 05-17-2022, 12:10 PM   #35
MatthewAMEL
MatthewAMEL's Avatar
Superchargers and N/A motors lose power at the same rate due to atmospheric conditions.
Superchargers spin at a fixed rate relative to engine RPM since they are belt driven.
Turbos spin at a variable rate related to exhaust gases. It may take longer for a turbo to reach a given PSI, but it can spin faster to compensate. It's why the preferred method for FI aircraft piston engines is turbos.
And barometric pressure has nothing to do with power. The term you are looking for is 'partial pressure'. Since it's the O2 that causes combustion in the chamber, it's the amount of O2 in a given volume of air that matters...not it's absolute pressure.
Cars in Florida make the same power when the meter is 30.00 or 29.40.
2017 HBM SS 1LE
Sold
2023 Wave Metallic
CT5-V Blackwing M6
2025 Hysteria Purple
C8 Z07
Old 05-17-2022, 12:35 PM   #36
mariojas
mariojas's Avatar
Drives: 2022 ZL1 M6 & 2023 Stinger GT AWD
But SC has pressure limit which means that (if RPM allow) maximum pressure will be the same, no?
2023 Kia Stinger GT AWD - as a family car...
2022 ZL1, M6 as daddy's ass mover
Charger sold! Better to sell, than waiting to be stolen...
mariojas is offline   Reply With Quote
Old 05-17-2022, 12:45 PM   #37
JSH
JSH's Avatar
Drives: '20 ZLE
There's no need to make this even more complicated. Atmospheric pressure is the sum of the partial pressures of its two gases - oxygen and nitrogen; and atmospheric pressure and oxygen pressure fall roughly linearly as altitude increases. No one in the history of internal combustion engine racing focuses on partial pressures.
Atmospheric pressure, or barometric pressure, is the key element of internal combustion engine power.
2020 ZL1LE A10.
Old 05-17-2022, 02:07 PM   #38
MatthewAMEL
You kinda got it, but you are way off when you say no one in racing focuses on partial pressure. You may know 'partial pressure' by it's common term...density altitude. Ask anyone who races if they care about the DA.
2017 HBM SS 1LE
Sold
2023 Wave Metallic
CT5-V Blackwing M6
C8 Z07
Old 05-17-2022, 05:28 PM   #39
JSH
JSH's Avatar
Drives: '20 ZLE
In summary, psia at 7000 ft elevation is 11.35, so:
11.35/14.7 = 77% of sea level atmospheric pressure in the intake manifold, or a 23% loss of power, even more than in Denver
Originally Posted by Camaroking98 View Post
Hey guys, been trying to do some research. Haven't really found a definitive answer or calculator...
I just moved to colorado (6700 feet) and I was wondering how I could calculate the power loss.
I've read that N/A loses the most power...then superchargers...and turbos are virtually unaffected.
Just wondering if you guys can help me properly guestimate how much power I'm losing up here.
2020 ZL1LE A10.
power loss, zl1, zl1 altitude
